03 Tiburon Head Unit Installation
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21562
Printed Date: April 03, 2026 at 1:59 PM
Topic: 03 Tiburon Head Unit Installation
Posted By: bdeboard
Subject: 03 Tiburon Head Unit Installation
Date Posted: November 16, 2003 at 6:50 PM
I have an 03' Tiburon with the full blown infinity stock system, I already added an amp and a sub but now I want to add my new head unit, the only problem is the wire color codes between the New head unit's connecter and the wire harness of the car aren't the same so I don't have any idea as to which go where. If anyone can help me I would greatly appreciate it.
-Brandon
Posted By: italnpimp59
Date Posted: November 16, 2003 at 8:11 PM
did you buy the wiring harness specifically made for that car?  you can buy one that plugs into your factory wiring harness and the colors will match up.  its simple.  make sure you hook up the amp turn-on wire to turn on your factory amp.
Posted By: MAXST
Date Posted: November 16, 2003 at 8:17 PM
ya, they wont be the same. Scroche harnesses have different colors.  inside the box they have a code to say which is which...then you match that to the new HU's- included in the install manual.
I need quality equipment, feel free to donate.
Posted By: Christene
Date Posted: November 16, 2003 at 11:17 PM
www.hmaservice.com is your  hook up they'll have wiring diagrams of your car in the electrical section
