How Far Apart Do You Space Screws on Boxes?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21614
Printed Date: April 04, 2026 at 5:25 AM
Topic: How Far Apart Do You Space Screws on Boxes?
Posted By: MAXST
Subject: How Far Apart Do You Space Screws on Boxes?
Date Posted: November 17, 2003 at 6:19 PM
Ok..nearing assembly time...
question is...how far apart do you all space the screws on your boxes?
Also, would it do any good to put polyfill in?
I need quality equipment, feel free to donate.
Posted By: Ketel22
Date Posted: November 17, 2003 at 6:36 PM
i usually space the screws about 1.5" apart to keep bending to a minimum.
Quad L Handyman services
Posted By: wvsquirrel
Date Posted: November 17, 2003 at 7:15 PM
Between 1" and 1.5" should be fine. Make sure you Pre-Drill the holes to prevent splitting. Countersinking the holes may make for a neater covering job as well.
Polyfill is mainly used to make an enclosure that was built too small sound larger. I believe the general rule of thumb with it is 1 pound per cubic ft. I'd listen to the enclosure first, then experiment with different amounts of polyfill until you get the sound that you want.
If you're building a ported enclosure I wouldn't recommend it though. The polyfill can be blown out of the ports!
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Posted By: MAXST
Date Posted: November 17, 2003 at 7:26 PM
ok. its sealed after each sub is in it should be around 1.3cu ft
Also, would it be wise to make the baffle double boarded...to sections cut out and glued together?
Posted By: MAXST
Date Posted: November 17, 2003 at 8:56 PM
Nother question...didnt feel i should make another thread.
I have a kenwood amp..with a lpf in it..would it be better if i got a crossover to control the freq in more?
And which one that is good for my budjet install? I also want to add another amp for some speakers...maybe components so a low and mid/high would be kool...
