Amp opinions and info
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21688
Printed Date: April 23, 2026 at 5:53 PM
Topic: Amp opinions and info
Posted By: kenmci
Subject: Amp opinions and info
Date Posted: November 20, 2003 at 12:01 AM
Can anyone give me there opinions and information about amps from the following companies:  Orion, Diamond Audio ( both  the D7 and D5 series) and Xtant.  Opinions about these amps, comparisons, and other suggestions would be appreciated.  I am going to buy a 4 and 2 channel amp, each from the same company.  The 4 needs to be 4X75 to 4x100 watts rms @ 2 ohms.  And the 2 channel needs to be 500 to 600 watts rms x 2 @ 2 ohms
Posted By: wvsquirrel
Date Posted: November 20, 2003 at 6:17 AM
You would be better off using a Mono amp for the subs. Class D's are usually cheaper per watt then Class AB's (even with the high end amps you mentioned).
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Posted By: EzekialPhoenix
Date Posted: November 20, 2003 at 10:10 AM
First of all, I am not an installer, so I haven't had the luxury of hearing dozens of different amps.  With that said, my opinions are based on what I have heard and what the specs look like.  Also, you really should try to go to a stereo shop and listen to those amps.  But, if you are hellbent on those three companies, and both amps must be from the same company, and you want the 4 channel and the two channel, Xtant is out.  Xtant makes a great 4 channel amp that would be appropriate for your needs, but they do not make a two channel amp in that range of power or even close.  They do make a mono amp that will put out the amount of power you are looking for, but not a two channel.  So, that leaves Diamond Audio and Orion.  I have heard the D7 amps, and personally I think they are wonderful.  My friends runs one of the D7 amps to his Diamond components and they sound amazing.  I haven't heard Orion in many years, so I'm not too sure how they're sounding these days, but I have heard good things.  I would go with the Diamond audio D7402 and the Diamond Audio D7104 if money was not an issue.
I be tossin and flossin, my style is awesome. Causin' more family feuds than Richard Dawson.
Posted By: bberman1
Date Posted: November 20, 2003 at 11:49 AM
Orion is a good amp for SPL, But if your looking for SQ go with the Diamond or Xtant. Between the Diamond and the Xtant I would defiantly go with the Diamond for the best over all sound .Now it sounds to me from past posts that you’re looking for a good sq system that can make some serious sounds if needed. About a year back I my self decided to with Diamond Audio to power my system. I used to constantly change out equipment, cause I always felt I could get better sound, I have a D7104 and a D7402 (used to use (2) D7401's then went to the D7402) and it’s the first set of amps that I have been satisfied with. If you want the ultimate in sound and can afford it go with Diamond. From the specs you gave above I would go with the D7104 and a D5 1200.1 (wire your subs in parallel for a 1 ohm load)
