remove factory deck 2000 prelude
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22654
Printed Date: April 02, 2026 at 7:10 AM
Topic: remove factory deck 2000 prelude
Posted By: dgonek
Subject: remove factory deck 2000 prelude
Date Posted: December 10, 2003 at 12:46 PM
Hey,
I am in the process of replacing my factory CD player and adding on a new deck and CD changer...
what r some tips to easily remove the deck and save me some time and frustration?
as well, if i want to install the changer inside the vehicle and not in the trunk, what is the best way to go about this?
thank
Posted By: bfog99
Date Posted: December 10, 2003 at 1:11 PM
Here is a website link that will tell you how to remove you stock cd player. Are you asking where other place are to install the changer? or just tips? I know some people install them in the glove box or under a seat.
Posted By: Velocity Motors
Date Posted: December 10, 2003 at 1:12 PM
1) Using a panel tool carefully pry upward on the radio dash bezel and remove. 2) Remove (2) screws holding the stereo sub dash piece in place and remove. 3) Remove (4) screws holding the stereo to the stereo sub dash. 4) Unplug all wiring.
------------- Jeff
Posted By: dgonek
Date Posted: December 10, 2003 at 1:15 PM
alright...
a) i don't currently have a panel tool - where can u get one?
b) bfog99 - where is that website link?
Posted By: bfog99
Posted By: bfog99
Date Posted: December 10, 2003 at 1:18 PM
i have used a flat head screw driver before to remove trim. anything thin but strong enough to pry a little bit. once you get part up you should be able to use your hands.
Posted By: dgonek
Date Posted: December 10, 2003 at 1:20 PM
and so once u get the trim off around the deck, then it just pulls out, or are there additional screws at the back of the deck as well to remove first before that can happen?
Posted By: bfog99
Date Posted: December 10, 2003 at 1:23 PM
Once you get the paneling off, there will be 6 screws. (2) holding the stereo sub dash piece in place and (4) holding the stereo to the sub dash. You can get a panel tool from crutchfield.com for 8.99 plus shipping.
Posted By: dgonek
Date Posted: December 10, 2003 at 4:02 PM
okay, now am i going to have to bypass the factory amp with the rear speakers, because i have been reading that the rear speakers have a higher resistance (4 ohm compared to 2 ohm on the others) and can overheat the head unit that is put in...is this true?
Posted By: bfog99
Date Posted: December 10, 2003 at 4:08 PM
The 4 ohm speakers will be fine with the deck. The ones you will need to hook up to an amp or something will be the 2 ohm.
Posted By: dgonek
Date Posted: December 10, 2003 at 4:11 PM
yeah, i mentioned the wrong ones - the 2 ohm are the rear speakers correct? so can i just use the factory amp with those, or do i need to get an aftermarket one?
