wiring 3 warren g 12's
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=23247
Printed Date: March 21, 2026 at 5:41 AM
Topic: wiring 3 warren g 12's
Posted By: tee17
Subject: wiring 3 warren g 12's
Date Posted: December 23, 2003 at 7:35 AM
i have 3 warren g 12's(by jvc). that are 1000 wattes each. i am putting them on a bd. 1000 amp or a 1000 watt soundstream amp. i have both of these amps at my expense and i wanted to know which one would be the best and how would i wire this setup to get the most out of it.
Posted By: bberman1
Date Posted: December 23, 2003 at 1:47 PM
Your subs are 350 watts rms DVC 4 Ohm, the BD1000.1 is 500X1 @ 4 ohm or 1000X1 @ 2 Ohm. I don’t know the rating of the Soundstream without the model number, but the Fosgate would be my first choice If you go with the BD1000.1 wire your subs in Series / Parallel https://www.audiobahninc.com/tech/wiring/series-parallel.html for a 2.67 ohm load on the amp.
