Sub output only
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=23269
Printed Date: March 20, 2026 at 6:57 PM
Topic: Sub output only
Posted By: timdog
Subject: Sub output only
Date Posted: December 23, 2003 at 5:33 PM
Dipped into the Christmas bag early to see what the jolly one will bring. I asked for a new stereo and gave some specs, it has RCA outputs for Front and Rear, and one for sub output. I want to hook my 2 15's up, do I use a splitter on hte sub output to my amp input? Thanks for the help
Posted By: Geeque
Date Posted: December 23, 2003 at 5:53 PM
You can run a single patch cable to the input on the amp.
------------- Gary Kline
MECP Master Technician
Posted By: timdog
Date Posted: December 23, 2003 at 6:03 PM
Wouldn't that only allow me to drive one of the subs? Like if I hooked it up to the L on the amp, then it would only drive the left sub. If I hook the speakers in series then, I drop to 8 ohms...not good. I don't know if the amp is 2 Ohm stable (recommends 4 Ohm).
Posted By: dcgc
Date Posted: December 23, 2003 at 6:10 PM
the *one* preout is mono therefore only one is needed for the sub amp. unless the sub amp is driving in stereo then only the one would be all you would need, If the amp recommends 4 ohm stay with that
------------- 2003 Silverado Ext. cab
Kenwood mp922
Kenwood kgc6042a EQ
JL Audio xr650-csi
MB Quart PSC 213
JL Audio 300/4
pair of JL Audio 12w6v2
JL Audio 1000/1
Posted By: dcgc
Date Posted: December 23, 2003 at 6:13 PM
* then only one would be all you would need*
correct that to state *if the amp is a stereo (2 channel) amp then you could use the splitter but you would still have a mono signal at the amp.
Kenwood mp922
Kenwood kgc6042a EQ
JL Audio xr650-csi
MB Quart PSC 213
JL Audio 300/4
JL Audio 1000/1
Posted By: timdog
Date Posted: December 23, 2003 at 6:15 PM
My amp is set up for 2 channel, L and R...so a mono out would need to be split to drive 2 4-ohm subs. Any modification outside that changes the current and I would like to avoid that. Splitting it shouldn't do anything adverse is my question...besides cutting the 5V down to 2.5 each input.
Posted By: dcgc
Date Posted: December 23, 2003 at 6:45 PM
Is this amp bridgable?
Stable at 2 OHMS?
your right the 5V would be split to 2.5V each. The only difference this is going to make is the SQ, honestly I don't think there would be that much of a noticable difference on the subs.
Kenwood mp922
Kenwood kgc6042a EQ
JL Audio xr650-csi
MB Quart PSC 213
JL Audio 300/4
JL Audio 1000/1
Posted By: bberman1
Date Posted: December 23, 2003 at 7:16 PM
Most likely the sub output on the head will have a 2 channel output. If it dose not then put a Y on the one channel and split it to 2 channels (there are no adverse affects other then the signal will be mono). But do you know the make and model of your headunit, amp and sub?
Posted By: NaughtyLMnky
Date Posted: December 23, 2003 at 9:47 PM
where do you get a head unit with a mono sub output? I've never seen that.
Posted By: Alpine Guy
Date Posted: December 23, 2003 at 9:52 PM
its called buying quality products.....alpine....and so on...
Date Posted: December 23, 2003 at 9:54 PM
I've never seen it on any alpine I used. I had one damn near top of the line from them too.
Date Posted: December 23, 2003 at 9:55 PM
Is it a new thing? I've kinda been outta touch with things for like 3 years though.
Posted By: timdog
Date Posted: December 24, 2003 at 8:04 AM
It is a present from the wife, most will come with 2...this one has 1...Alpineknucklehead was just being sarcastic. Anyway, I gave her some specs, this is what she came back with...so I will use it.
Posted By: dcgc
Date Posted: December 24, 2003 at 8:51 AM
wonderful gift by the way. Next time suggest you buy yourself something for yourself. I did: JL 1000/1
Kenwood mp922
Kenwood kgc6042a EQ
JL Audio xr650-csi
MB Quart PSC 213
JL Audio 300/4
JL Audio 1000/1
Posted By: eargasm
Date Posted: December 24, 2003 at 7:54 PM
i had sub-out on my alpine tapedeck NaughtLM. And that was 6 years ago. front pair, rear pair, sub pair. 6 RCA's coming out the back. Had full sub control, for on/off and volume 1-15. seen plenty of decks like this. never seen one with a single RCA for the sub output. But, if i did, I'd just use a Y-piece splitter. ------------- 2001 Ford Fairmont
Alpine DVD, screen,
5.1surround processor,
5ch Class-T amp, TV tuner
and centre channel.
Focal 3way Utopia splits.
VDO navigation. Stinger cap.
Soundstream Exact subs.
Posted By: eargasm
Date Posted: December 24, 2003 at 7:56 PM
Actually, my current Alpine surround sound processor only has 1 RCA for sub-out. And I did use a Y-splitter. works fine.
Alpine DVD, screen,
and centre channel.
Date Posted: December 25, 2003 at 8:58 PM
Well i know that a lot can be set up in a mono mode but I have always seen two rca's coming out of the unit. I was thinking to myself "Quality product? Look for something that you have to split the rca to send signal to an amp and reduce your sound quality. Just doesn't seem to be a feature I am going to look for."
Date Posted: December 25, 2003 at 9:00 PM
I'm sure it will work fine just to use a splitter for the subs but I would think you start to sacrifice sound quality if it were for highs or mids.
Date Posted: December 25, 2003 at 10:45 PM
im splitting my speaker amp, and i didn't notice anything, shure i may have needed to turn up my gain a little more tho. I really should save up for the other RCA cable.
