Plymouth Acclaim -Low Audio
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=23270
Printed Date: March 20, 2026 at 8:55 PM
Topic: Plymouth Acclaim -Low Audio
Posted By: davis911
Subject: Plymouth Acclaim -Low Audio
Date Posted: December 23, 2003 at 6:18 PM
I installed a PIoneer deck in my in-laws 91 Acclaim, all the spaekers are hooked up, but it is real low volume, almost like there is a MUTE or ATTENTUATOR on the deck but there isn't one (that I can find) anyways there were a few other wires from/to the factory head unit that are not installed, I am wondering if there is some wire that should be hoked up that isn't?????
Hooked up are the 8 speaker wires, ground, power and accesory
Whats up????
Shawn
Thank you
Posted By: bberman1
Date Posted: December 23, 2003 at 7:20 PM
I don’t have a wiring diagram for that vehicle, but it sounds like it may have a factory amp. If it dose you need to hook up the remote wire Blue/white from the headunit to the +12 volt Switched power on the factory amp. That will allow the factory amplifier to turn on and amplify the signal from the headunit.
Posted By: davis911
Date Posted: December 24, 2003 at 12:31 AM
Thanks BB
Thats kinda what I was thinking. Please does someone know what wire this is???
Shawn
Thank you
