How can i hook up 6 mids on a ZR 120
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=23320
Printed Date: March 21, 2026 at 11:42 PM
Topic: How can i hook up 6 mids on a ZR 120
Posted By: DLW18
Subject: How can i hook up 6 mids on a ZR 120
Date Posted: December 25, 2003 at 1:59 AM
I am wondering if it is possible to hook up 4 to 6 mids on a ZR 120 and get the full sound and how can it be done....ASAP...all the mids are 2 way pioneer 100watts 4x6
Dustin White
Posted By: DLW18
Date Posted: December 25, 2003 at 2:01 AM
please let me know as soon as possible
Dustin White
Posted By: Durwood
Date Posted: December 25, 2003 at 2:46 AM
You can do four mids without too much trouble.  Each mid is a 4-ohm load, and the amplifier is 2-ohm stable in stereo mode.  So for each channel, use two of the mids wired parallel with each other.  This way, each channel of the amp will see a 2-ohm load.  You'll get 60 Watts per channel out of this setup, which is the most that amp is good for.
Scott Gardner
Posted By: forbidden
Date Posted: December 26, 2003 at 11:47 AM
You can also hook all the speakers up in parallel, like Scott described above, it will have 3 speakers per channel, now this may be beyond what the amp is designed for but seeing as they are mids that don't draw a huge amount of current (unlike 3 subs per channel) you may be OK, keep the gain turned down for sure, no bass boost etc. Try it and find out, if the amp shuts off, it may be due to overheating, which means, disconnect 1 pair of mids, then try again.
