1996 Toyota Corolla stereo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=23343
Printed Date: March 14, 2026 at 1:34 PM
Topic: 1996 Toyota Corolla stereo
Posted By: kolbie2005
Subject: 1996 Toyota Corolla stereo
Date Posted: December 25, 2003 at 6:07 PM
I have a 1996 toyota corolla le
I bought 2 10"s and an amp from best buy. I ddint not want to have them install it, they wanted to charge me $120 with wires to do it. I was wondering if anyone had any pictures or instructions so i can do this with out messing up my car or audio system
thankx
kolbie
Posted By: Durwood
Date Posted: December 25, 2003 at 6:37 PM
Well, depending on what kind of amp and subs you bought, you may need several additional components to make this work.  Does the amp have high-level inputs so you can connect it to the speaker wires already in your car, or does it just have RCA inputs?  Does the amp have a low-pass filter to keep the high frequencies away from the subs?  If not, you'll need to install one.  Are you going to wire the subs together and bridge the amp mono, or power each sub with a separate amplifier channel? (I'm assuming you got a stereo amp).
Give us the brand and model for the subs and amplifier, and I'm sure we'll be able to give better suggestions.
Scott Gardner
Date Posted: December 27, 2003 at 1:00 AM
I have 2 Dual 10's wioth a 430 watt Dual amp
does that help?
kolbie
Posted By: Durwood
Date Posted: December 27, 2003 at 1:07 AM
Not really.  We need to know the impedance of each voice coil in your subs to tell you how best to hook them to the amp.  Also, is your amp stereo or mono?   By "Dual", I'm assuming you mean "stereo".  Can it be bridged to mono?  What's the lowest impedance it can handle in stereo? in mono?
Honestly, a brand name and model number for the subs and amp would really help.
Scott Gardner
