2 Comp vrs in Slot port box
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24108
Printed Date: March 27, 2026 at 4:18 PM
Topic: 2 Comp vrs in Slot port box
Posted By: lost_logan
Subject: 2 Comp vrs in Slot port box
Date Posted: January 07, 2004 at 12:34 PM
ok i have 2 Comp VRs dual 2 Ohm vc they will be wired in series/parrel for a 2 ohm load and im playin on buildin a slot port box any ideas on what size to make it
p.s. they will be goign in a 91 chevy reg cab wit stock 40-60 split seat
the amp is a legacy... i kno no cash for new one tho
Date Posted: January 07, 2004 at 12:42 PM
there the 10's
Posted By: mindctrl
Date Posted: January 07, 2004 at 3:48 PM
Well, in the future, just go to the manufacturer's website and look up their product specs... But I already did it for you so theres no point now =P.
Make the box out of 1" MDF, with at least 1.25 cubic feet of airspace in the interior per sub, but no more then 1.75 per sub.  This gives you a little to play around with.  I would suggest going 1.5 cubic feet per sub, giving you a total of 3 cubic feet, so that will give you some space to err.  Make sure you isolate the subs from each other(build a barrier on the inside of the box and seal it with some liquid nails.)
I have no clue what to do for your slotted port, however, since I don't know what the regular port tuning is... Any other questions?
--mindctrl
Date Posted: January 07, 2004 at 8:08 PM
i kno but there older comp vr's so i was not to sure bout that.
any one kno if u can amke the slot inside the box any size but make the opening a certian size?? and how do i tune it
Posted By: mindctrl
Date Posted: January 07, 2004 at 10:51 PM
Well you need to find out the specs of your subwoofers before I can help you figure out the port size.  Call Kicker.
--mindctrl
