Eclipse Infinity amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24144
Printed Date: March 27, 2026 at 1:07 AM
Topic: Eclipse Infinity amp
Posted By: frazierk
Subject: Eclipse Infinity amp
Date Posted: January 07, 2004 at 8:52 PM
Looking for the pin out for the din connector for an Infinity amp (oem) in a 1998Eclipse (din hooks to Factory radio). Would like to hookup aftermarket radio.number on amp is MR158402
KJF
Posted By: boomer_106
Date Posted: January 08, 2004 at 12:44 AM
Try this link. If your not sure use their contact us button and ask a tech if its what you need.
https://autosoundgear.com/tek9.asp?pg=search&mode=results
Posted By: frazierk
Date Posted: January 08, 2004 at 7:42 PM
Link was great THANKS! I can make my own (for a whole lot cheaper) if I can find the pinout................
KJF
Posted By: richs
Date Posted: January 18, 2004 at 4:04 PM
Just to let you know in case you didn't want to cut the factory din cable, SoundGate (and others) make a din-to-RCA cable for this purpose. In the factory din there are 4 audio, + 1 audio - and an amp turn-on lead.
Best Regards,
Rich
