MTX Powered Thunderform
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24260
Printed Date: May 05, 2026 at 7:41 PM
Topic: MTX Powered Thunderform
Posted By: eddiec
Subject: MTX Powered Thunderform
Date Posted: January 09, 2004 at 1:57 PM
Hi guys. Some of you helped me with my alarm install & with your help it was a success. I have a question about an MTX powered thunderform I just got off of ebay. I hooked it up but if I turn the gain up any at all, The speaker will start thumping very....well, kinda fast. The guy I got it from "says" it was working fine when he took it out of his car 2 months ago. Is there anything simple I can look for or should I consider that money out the window? Thanks for your help. You guys are great!
Posted By: forbidden
Date Posted: January 09, 2004 at 2:14 PM
Double check the ground from the amp. If the thumping is at the same level and rhthym, then you may have a bad amplifier.
Posted By: eddiec
Date Posted: January 09, 2004 at 2:20 PM
I'll check when I get off but I think the thumping gets louder and a little faster as you turn the gain up.
