Ford Focus head unit pinouts
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24329
Printed Date: May 04, 2026 at 1:07 PM
Topic: Ford Focus head unit pinouts
Posted By: eBoyDog
Subject: Ford Focus head unit pinouts
Date Posted: January 10, 2004 at 5:05 PM
Been a long time user of the forum as I do some audio installations on the side, great site and info!!
Thought perhaps this would be helpful to those who are picking up those Ford Focus, Cougar head units on eBay and such, I searched the internet everywhere, finding only color code diagrams of the Focus audio wiring.
found it overseas on https://www.david.lanham.btinternet.co.uk/radio_wiring.htm
I was trying to get a Focus head unit installed in a Ford ranger because I had a OEM Blaupunkt CDC adapter that only fit the Focus CDC port which in turn would allow me to hook up a MDP-01 Blaupunkt MP3 player....  Short answer is that I found it won't work, Blaupunkt's tech support claimed that it might (Ford head unit, Blaupunkt CDC adapter, Blaupunkt MP3 player), connectors all fit but the technical aspect didn't allow it
FYI - While the standard older Ford connectors physically fit, the standard pinouts that Ford has used for years are not the same that the newer (2000+) Focus and Cougar head units use.  I can confirm that the pinouts from the above link are correct at least for the power and speakers (there are other pin functions but I didn't verify them)
Posted By: eBoyDog
Date Posted: January 13, 2004 at 7:59 AM
I believe the  Premium Focus Blaupunkt MP3 head unit has the following pinouts (uses ISO plugs)
posted_imagehttps://www.bluespot.co.uk/stock_image/iso.jpg">
posted_image
posted_image
Right Rear
(1)
Right Front
(1)
Left Front
(1)
Left Rear
(1)
Right Rear
(2)
Right Front
(2)
Left Front
(2)
Left Rear
(2)
posted_image
posted_image
Phone muteN/CAuto aerial+12v
Ignition
N/C+12v
Battery
IlluminationEarth
Speaker ISO connector (B plug)
Power ISO connector (A plug)
