Amp recommendations
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24503
Printed Date: May 02, 2026 at 7:34 AM
Topic: Amp recommendations
Posted By: snowdeath
Subject: Amp recommendations
Date Posted: January 13, 2004 at 11:27 AM
I need an amp to power two 10w6v2's
What amps would you recommend: brands / models
I know I need something 800w rms but what brand and model amps do you recommend to get the best out of these subs
I'm looking to spend up to $550 on ebay for an amp.
Posted By: ksin291
Date Posted: January 13, 2004 at 3:01 PM
If you are willing to spend that much I would probably match the subs up with a JL Audio 500/1. I have seen this amp outperform many higher rated amps hands down. I highly recommend Jl amps as the quality of these amps are unsurpassed, what I like most about the JL Audio /1 amps is that they give you the same output no matter what, as long as the ohm load is between 1.5-4 ohms you are set. Also you don't need something that will put out 800 watts rms, rms on your subs is 400. You should be able to score the 500/1 on EBay for $350-$400 brand new. If you want another option Memphis Car Audio makes some really good amps and you should be able to score a 1000D for around $400, in fact I'm selling one.
