Stock amp and sub
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24528
Printed Date: May 01, 2026 at 8:55 PM
Topic: Stock amp and sub
Posted By: subtleaproach70
Subject: Stock amp and sub
Date Posted: January 13, 2004 at 7:02 PM
I have a 1999 Ford Expedition w/ Mach sound system.  I put an Alpine CVA 1004 in it.  Everytime I turn up the volume to around 17-20, the sub starts cutting out.  Any thoughts on this?
Wildkind Concepts
Posted By: sparkyssb
Date Posted: January 13, 2004 at 7:20 PM
I would have to say the amp for the sub is recieving too much power for it to handle. Usually a factory stereo does not put out as much power (watts) than an aftermarket. I read in a post concerning a MACH sound system that Ford put a saftey feature into the system so that if the volume was turned up too high, it would fade the bass so it would no blow the speakers/sub. However, I read that it was the actual factory head unit that did this. Hmmm..sounds like Ford put the feature in the factory amp also.
I'm fairly certain the amp is in the back of the SUV. You might need to bypass it with a different amp.
Hope this helps!
Eric
Date Posted: January 13, 2004 at 7:28 PM
This site *might* help you out.
Take care,
Eric
Date Posted: January 13, 2004 at 7:47 PM
Eric,
Good site, but it doesn't have any infor for Ford Expedition.
Wildkind Concepts
Posted By: geepherder
Date Posted: January 14, 2004 at 12:53 PM
Yeah, I'd say the factory setup isn't up to the task.  Like Eric said, the amp's probably overwhelmed by the amount of input power it's recieving.  I'd say just disconnect it- if not ripping it out completely.  There are a couple Thunderform enclosures available if you still want your bass- one being powered and the other not powered.
Posted By: richs
Date Posted: January 18, 2004 at 3:51 PM
How is the factory sub amp connected to the new radio? First thing you need to do is install a 570 ohm resistor in the turn-on lead. The factory turn on runs at 5 volts and as you turn up the volumn on the factory system, the voltage increases which will decrease the output from the factory sub amp. It is a clip detect system to prevent damage to the sub and amp. The 570 ohm resistor will prevent the amp from freaking out with the 12 volt turn-on signal. And like said by others, you may be over driving the factory amp inputs. Won't know until I know how it is hooked up now.
Best Regards,
Rich
