newbie seeks help with wiring 2 amps
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24868
Printed Date: May 01, 2026 at 1:51 PM
Topic: newbie seeks help with wiring 2 amps
Posted By: shagback
Subject: newbie seeks help with wiring 2 amps
Date Posted: January 19, 2004 at 10:32 AM
I just bought a US acoustics USB600D. It's rated RMS 300 watts x 1 at 2 ohms and I plan to use it to drive 2 10in kicker subs. My present amp is an MTX 102D (RMS 25 Watts x 2 into a 4 Ohm load at 12.5v) powering a pair of component speakers up front.
My questions are about my 8 ga wiring from the battery to the MTX amp. Is it ok to use present wire and just add a distribution block? Where can I buy a distribution block that accepts one 8 ga and outputs 2 8 ga? Is this correct for the power requirement of the 2 amps or do I have to tear up the wiring and go one 4 ga input to two 8 ga outputs?
Also I am just planning to connect the blue remote turn on wire from head unit to the 2 amps in series. Is this ok? What about ground, can I use the same grounding point on the car chassis for the 2 amps?
TIA!
ps. if you haven't bought anything from crutchfield b4 and plan to, use my referral code  pwkef-ttq28-0ksy5 and receive a $20 credit for orders > $200. You'll give me a credit as well :D
Posted By: Teamrf
Date Posted: January 19, 2004 at 11:14 AM
Me personally I would run 4awg wire and use a distrubution block to run 8awg to the other two amps. You can use the same grounding point for both amps...in fact that is the best way. As far as the remote wire...you can use a relay or just jump it off one amp to the other. Hope this helps...ask if you have anymore questions.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: DYohn
Date Posted: January 19, 2004 at 11:30 AM
Your amps will pull a total of 350 watts so you can stay with yout 8 AWG as long as the total length of the cable from your battery to either amp is less than 8 feet.  If the cable is longer than 8 feet, go up to 4 AWG from the battery to your distru block, than then 8 from there to each amp.  Jumping your remote lead from one amp to the other should be fine.
Posted By: customsuburb
Date Posted: January 19, 2004 at 12:59 PM
You might want to get a relay if you buy another amp so you dont burn out your HU's turn on circuit.
Date Posted: January 19, 2004 at 1:01 PM
You only might want to look into this if you have more then three amps actually.
Posted By: shagback
Date Posted: January 19, 2004 at 2:38 PM
Thanks for all your replies!
