Navigator 2003 - Adding Sat Radio
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24995
Printed Date: April 30, 2026 at 8:19 PM
Topic: Navigator 2003 - Adding Sat Radio
Posted By: franc11s
Subject: Navigator 2003 - Adding Sat Radio
Date Posted: January 21, 2004 at 9:52 AM
I am adding a Sirius Radio to my wifes Navigator. 2003. It has full Sat Nav, touch screen and all that.
How easy is it to add the modulator I've bought inbetween the ariel and radio and where can I pick up power that will go off when I take the key out.
I went the modulator route becuase there does not seem to be an aux in on this touch screen factory system.
Is this easy? What panels should I remove and how ? Are there any instructions anywhere ?
Thanks ever so much
Posted By: raydawg357
Date Posted: January 21, 2004 at 12:58 PM
The modulator is fairly easy.  On the sirius models, you have an accessory wire and a ground wire.  Then you plug the your antenna into the modulator and the antenna end from the modulator into your radio.  The only draw back with fm modulated systems is if you travel a lot, your signal may become weak and will have to search for another station to receive the sirius signal from.  Your Navigator may also require antenna adaptors.
Do it right the first time
