audio setup opinions?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25191
Printed Date: March 31, 2026 at 10:41 PM
Topic: audio setup opinions?
Posted By: faus03
Subject: audio setup opinions?
Date Posted: January 24, 2004 at 12:01 PM
im going to replace my door speakers and put better subs in. this is what i am planning on using. 6.5 infinity kappa60.5cs, 2 10 inch audiobahn awc10t, and a rockford 801s amp. all these can be found on ikesound.com, thats where i found them. let me know what you think of these. thanks in advance
Posted By: faus03
Date Posted: January 24, 2004 at 12:04 PM
either those subs or the audiobahn aw100t, with the same wattage rms.
Posted By: customsuburb
Date Posted: January 24, 2004 at 3:00 PM
Look at JL audio's W3v2s also if you can : https://www.jlaudio.com/subwoofers/10w3v2.html
Posted By: italnpimp59
Date Posted: January 24, 2004 at 6:56 PM
audiobahn subs are absolute garbage.  the amp is a good choice and so is the door speakers.  audiobahn is all looks, the quality is non exsistent!!!
Posted By: faus03
Date Posted: January 24, 2004 at 9:04 PM
i picked the audiobahn subs because they are 400 watts rms which is perfect for the amp i picked. and also because the mounting depth is only 5 inches. keep in mind im working in a regular cap truck. so space is an issue. so if i knew how deep the jl's were that would help alot. and do you have any experience with audiobahn or are you just saying this about them. has anyone heard audiobahn? how do they rate?
Posted By: faus03
Date Posted: January 24, 2004 at 9:05 PM
another thing about the audiobahn subs is that they run 55 dollars. thats pretty cheap if you ask me for the power they say they put out.
Date Posted: January 24, 2004 at 9:08 PM
do i have expericne with audiobahn?  no i just pull random comments like that out of my ass all the time.  of course, thats why i said that.  im just trying to save you from wasting your money and being really pissed off.  they are 55 dollars for a reason!!
Posted By: geepherder
Date Posted: January 24, 2004 at 10:05 PM
Yeah, I'd have to agree with Jimmy.  Cheap subs usually have cheap sound.  Do you have a Frye's Electronics nearby- I think I've seen some Audiobahn gear there before.  If so, give them a listen.  They won't tell you what they'll sound like in your car, but you can get an idea whether or not it'll be worth it to you or not.  In the end, it's your decision, so if you're happy, that's all that matters.
Posted By: forbidden
Date Posted: January 24, 2004 at 10:13 PM
As a dealer of these subs, they actually can sound pretty darn good, just make sure to match the subs to the proper box, use the right amp set up properly and do not abuse them and they will do a good job for you. Would they be my first choice, probably not, but it does not mean that they are no good.
Date Posted: January 25, 2004 at 5:18 PM
If your looking for something cheap that dosnt suk look at JL's W0 line of subwoofers.
Posted By: Alpine Guy
Date Posted: January 25, 2004 at 5:43 PM
also look at the alpine type-s line of subs, they are not deep at all, and slam pretty darn hard.  you have a choice of single 4 ohm, , or dual 4 ohm.   They are 200 watts rms, and 600watts peak.  With that amp they will pound to hell.  I just did an install friday with 2  Type-S 12's in a 89 ford f-150,  running 400w rms, they were sick.
Also look at the rockford subs,  im not shure if eclipse has a good sub with a shallow mounting depth, but if theyt do, theres a choice too.
Posted By: faus03
Date Posted: January 25, 2004 at 10:33 PM
thanks alot guys, i dont mean to affend anyone, i dont know anyone. so i just like to make sure that everyone has experience to back themselves up. as long as it sounds good to the level i want ill be happy. and i would like them to be as shallow as possible. it is in a truck. i will check around for the subs, if you guys find anything around 5 inches deep let me know. thanks so far.
