wiring subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25438
Printed Date: May 15, 2026 at 6:54 AM
Topic: wiring subs
Posted By: xTimx
Subject: wiring subs
Date Posted: January 28, 2004 at 2:17 PM
ok this has gotten me into a contemplation. i have DVC MA audio 12"s D6..posted_imageit says there that this is a DVC sub which if it was: If using Dual 2 ohm coils the total load would be 4.0 ohm.
If using Dual 4 ohm coils the total load would be 8.0 ohm.
If using Dual 6 ohm coils the total load would be 12.0 ohm
posted_image   this is the way i have my subs wired up right now to my amp(to get 6ohms). my amp can only do 2 ohm stereo, but i have these subs bridged on my amp.
posted_image now another one is that this one is a SVC sub: If using Single 2 ohm coils the total load would be 2.0 ohm.
If using Single 4 ohm coils the total load would be 4.0 ohm.
If using Single 6 ohm coils the total load would be 6.0 ohm
this is really confusing cause essientially can i wire up my subs like this posted_image but take out the wireing that connects the voice coils so they would be wired only as SVC to get a 3ohm load. would that be possible?!
Posted By: DYohn
Date Posted: January 28, 2004 at 2:41 PM
Your speaker has dual 6-ohm voice coils.  The only two setups for this speaker are 12 ohms (in series) or 3 ohms (in parallel.)  I recomend that if your amp can handle a 3 ohm load when bridged wire it in parallel.  DO NOT wire just one voice coil to your bridged amp.  If the amp is stereo and cannot handle a 3-ohm bridged load, you could connect each VC independently to one channel, as long as you are sending a mono signal split into both channels.  This would place a 6-ohm load on each channel.
Posted By: DYohn
Date Posted: January 28, 2004 at 3:12 PM
I just read another of your posts.  Do you have two of these woofers?  Then you have more wiring choices.  The total load you can place on your amp with two D6 woofers is either: 24 ohms, 6 ohms, or 1.5 ohms.
From your amp description (2-ohm stereo stable, which means 4-ohm briodged stable) I suggest you wire each sub with the voice coils in series (12 ohms each) and put these two in parallel at your bridged amp (6 ohms on the amp).  Any lower load will potentially damage the amp.
Please give complete information, including make and model when you can.  Thanks.
