99 Navigator Head Unit Space
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25450
Printed Date: May 15, 2026 at 11:25 AM
Topic: 99 Navigator Head Unit Space
Posted By: kidtransam
Subject: 99 Navigator Head Unit Space
Date Posted: January 28, 2004 at 6:55 PM
anybody know if a 99 navigator will hold 2 din size units stacked?...specifically a cd head unit and an in-dash dvd player. if so is there a special dash kit for this. thanx
With a torch and a big enough hammer...it WILL friggin fit!!
Posted By: forbidden
Date Posted: January 28, 2004 at 8:18 PM
If it is anything like a F-150 (truck country here, not upscale SUV, oh no it might get dirty) it may appear to be a double din, but if you remove the factory unit and look at the top of the dash cavity, chances are that it bends downwards about 5" in from the front. If this is the case, the only way you are going to be able to do double din is modifying the dash cavity. Check to see if this is what you have, chances are it is.
Posted By: maxxxaudio
Date Posted: January 28, 2004 at 8:48 PM
i believe the Snap On air saw is the tool of choice to remove the white colored plastic needed to fit units in the dash. as far as the kit, i fab mounts from back strapping. be careful not to go to high in the dash unless you want a new ash tray. good luck....Dave
big dave
