Hiss! Noise Problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25560
Printed Date: March 30, 2026 at 2:12 PM
Topic: Hiss! Noise Problem
Posted By: JustDoIt2
Subject: Hiss! Noise Problem
Date Posted: January 30, 2004 at 11:21 AM
HI, Guys , Im having problem with some noise coming through my speakers, Even with the volume at 0 you can hear kind of loud the Hiss... I have a pioneer Premier  deh-p840mp  and a Pioneer deq-9200 EQ.  and I have ground it to the Chasis, not to the wire coming from the harness/.. What could be the problem, or could i do to solve it...
Date Posted: January 30, 2004 at 11:25 AM
Oh, I forgot to tell you, I know where is coming from, I just got the Pioneer Premier DEW-9200 EQ< and If I bypass the eq connect just to the hu, no noise, no hess at all,  but is there any way i can do something to the eq to keep using because i just bought it less than i month and i spent like US$330.00
Posted By: DYohn
Date Posted: January 30, 2004 at 11:36 AM
The DEQ-9200 is a very sophisitcated unit but it is also known for being noisy.  If you have a gain mis-match it will introduce unacceptable levels of high frequency hiss.  Are you in "pro" or "standrad" mode?  I suggest you put it into standard more and go through the setup calibration procedure (as detailed in the owners manual) again to ensure your levels are correct.  If set up correctly, this unit can be great.  If set up incorrectly, this unit can destroy the sound of your system.
Date Posted: January 30, 2004 at 11:38 AM
IM using it in Pro Mode, I have two amp (bazooka) going to my bass and One amp (soundstream) going to my mids and high....   I will try doing that now to see what happens,, I will post the results..
thank you
Date Posted: January 30, 2004 at 11:40 AM
Its kind of hard to Set the EQ the way you want, its complicated to use, TO have to read the WHole mannual and im not good reading mannuals,,, but I will take the time to do if I really want my system to sound the way i want it..
thank you
Date Posted: January 30, 2004 at 1:26 PM
Both in Pro mode or Std, mode i still hearing the hiss, but I change some setting in the Pro mode and It reduce the hiss, so now I think the hiss is normal...  .......
I was told this Eq was known for being noise before i bought,
but now its fine....
Posted By: jeffchilcott
Date Posted: January 30, 2004 at 3:43 PM
try adjusting your high level controls on your head unit to 0    if you have any adjustments before the eq it could cause distortion or hissing
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
