Saturn Radio Install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25561
Printed Date: March 30, 2026 at 3:30 PM
Topic: Saturn Radio Install
Posted By: sparkyssb
Subject: Saturn Radio Install
Date Posted: January 30, 2004 at 11:23 AM
Hello,
My brother just recently installed a JVC aftermarket unit into a '94 Saturn SL 1. He used a Scosche wiring harness. Everything works fine except for the dash lights, parking lights, and tail-lights. He did NOT cap that illumination wire. errr. I'm fairly certain he blew a fuse for those items however he cannot find a fuse that is blown. He checked two boxes and pulled all the fuses just to make sure; everything is fine.
Anybody know where a fuse can be hiding in this car? Thanks!
Eric Lucas
Posted By: HeathMac
Date Posted: January 30, 2004 at 1:14 PM
did ya check the fuse box under the hood ?
Date Posted: January 30, 2004 at 4:11 PM
Yep..that was checked. Along with the one inside the car. Is there possibly an inline fuse somewhere?
Date Posted: January 30, 2004 at 8:03 PM
Ok..found the fuse. Near passenger door. Now, lights work but then radio goes dead and doesn't save settings. Factory radio works fine.
Ideas?
Thanks,
Eric
Posted By: chriswallace187
Date Posted: January 30, 2004 at 9:11 PM
Check the harness again, to make sure the colors are properly matched. It kind of sounds like the constant power and illumination wires got switched. Also, check to make sure the ground wire is hooked up properly. The wires on the factory harness should be:
orange - constant 12v +
black or BLACK/ white - ground
yellow - switched 12v + (this should be right next to the constant power)
Posted By: Clean Install
Date Posted: January 30, 2004 at 9:31 PM
agree with chriswallace187 sounds like a couple of wires are switched around....that should do the trick...
good luck
If we learn from each success and
each failure, then we can improve ourselves
