2000 Pontiac Grand AM-power problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25645
Printed Date: April 19, 2026 at 10:15 AM
Topic: 2000 Pontiac Grand AM-power problems
Posted By: sohx
Subject: 2000 Pontiac Grand AM-power problems
Date Posted: February 01, 2004 at 12:11 AM
Hey guys,
Check this out. This is what I have:
4-year old Kenwood Cd player
MTX AMP (425 W max) 2 chan.
2 - Pioneer Premier 10" subs
I personally installed the CD player (maybe that's the prob) and all my stuff worked fine. Later on 1 year later or so in my 2000 Pontiac Grand Am the amp started flickering on and off, also my internal lights flickered with this. Both the battery and the alternator are fine. At first I thought it was just the amp cause the rest of the channels sounded fine. Amp passed the test with flying colors. Later on I just plugged it all back up (amp )and it worked fine, strangely enough. Then the problem kicked in again 2 days later. Fuses fine. I just don't know why it would flicker.
1. Does this happen with a terrible ground connection?
2. Also today my friend tried plugging his cd player up to my connection to the car to see if the problem was a cd player issue. Problem was he didn't think that the color coding is/or could be different for each player or maker. Something probably friend, because there was a smoke smell coming from the car. He would fess up to telling me if he fried one of his older cd players. But I plugged in my previous cd player back and now no power comes to the player. What do you think he fried?
2. If he did fry something what do you think it could it be?
Anything would help guys.
Thanks alot!
Posted By: boomer_106
Date Posted: February 01, 2004 at 1:32 AM
Yes a bad ground could be causing problem number 1. Make sure the amps ground is clean and tight.  As for the second problem I would start by checking the associated fuses. If you have a multimeter you can check for the presence of 12 volts to the head unit.
Posted By: sohx
Date Posted: February 01, 2004 at 2:43 AM
Would that cause the flickering on number 1? Please anyone who's seen this reply.
Posted By: customsuburb
Date Posted: February 01, 2004 at 10:59 AM
It might. Check the area where your amp is grounded. Make sure the screw that you used to screw the ground wire to the vehicles chassis is tight and that the area where it is screwed into is clean(try to scrape away any paint where you have the screw and make sure it is clean. Try this and post back
Posted By: sohx
Date Posted: February 01, 2004 at 4:04 PM
I'll need to try that. However right now I'm stuck with problem 2. I tried using a DMM on my car to see what problems I have with the power to the deck. I can't get anything, the fuses for the radio are good too. What do you think I can do about this? It's possible I could just rewire the power, and ground. How do you recommend manually wiring the positive ignition wire?  Is there any other places I can check on my car other than the fuse box to see if there's something wrong with my cars power plug?
What a mess huh!?
Anything will help.
Thanks guys! Tim
Posted By: sohx
Date Posted: February 01, 2004 at 6:32 PM
Alright, So I'm retarded. There was an extra fuse panel in the car that I've never opened and I found the broken fuse. Radio works fine now. Only problem is.... I re-checked the grounding and positive cable to the amp and it's a clean tight job. However, when the remote line from the CD player kicks the amp on (usually) it starts the whole flickering issue in the car. Interior lights, headlights, all electrical seems to flicker. I recently had the battery replaced and the alternator is fine. Does this sound like some sort of other fuse in the car? What do you think?
Tim
Posted By: geepherder
Date Posted: February 02, 2004 at 12:48 AM
Sounds like you're draining the battery/charging system.  You could be drawing too much power.  You said you've already verified good power and ground.  If you disconnect the amp remote lead, does the problem stop?
Posted By: sohx
Date Posted: February 02, 2004 at 1:24 PM
Yeah the problem stops once I take the line off. Does this sound like it needs a capacitor or something? Not only does the car electrical flicker. But the amp doesn't even produce sound more than just clicking sounds to the subs. I just had the battery replaced. I had the alternator checked it seemed to pass fine. I didn't have it checked with the amp on, would that help? I thought alternators would slowly stop producing power and not just kick off. Everything else on the car electrical works fine. Except if I kick the amp on. What do you think?
Posted By: forbidden
Date Posted: February 02, 2004 at 1:42 PM
Try another amplifier, to me it sounds like a faulty amp. Did you infact get sound from your friends stereo when it was hooked up. If you did and the sound was clean and no flickering (describe what is flickering please) hten it will be a head unit or rca cable wiring issue. If with any cd player or discman you still have this flickering issue, then you either have a bad amp or bad wiring. Hook up a different set of speakers to the ap as well and use new wiring for it.
