Speaker size change Need Help!
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25702
Printed Date: April 19, 2026 at 5:57 AM
Topic: Speaker size change Need Help!
Posted By: neurosciguy
Subject: Speaker size change Need Help!
Date Posted: February 02, 2004 at 2:44 AM
Im want to put a 6.75 inch midrange driver in my doors where 6x8 factory speakers used to be. Im wondering how to go about doing this. Do they make conversion brackets or something for this purpose? If so where could i get them? Oh im trying to do this to the doors of a 2000 mustang. Thanks for any advice!!
Posted By: staudio
Date Posted: February 02, 2004 at 6:19 AM
Check with a local install bay, someone like best buy or sound advice, they usually have conversion brackets for stuff like this. If that fails you can make your own but its a little tedious so I'd check with an install bay before going any further.
Posted By: geepherder
Date Posted: February 02, 2004 at 8:35 AM
Yes, there are adapter brackets available, or you can make your own out of wood (some MDF will work great). All you need to do is flop your factory speaker upside down (magnet up), and trace the outside, then mark your mounting holes. Cut this out, and place your 6.5's upside down on these panels in the same manner. Mark what you need and cut.
------------- My ex once told me I have a perfect face for radio.
Posted By: Sweekster
Date Posted: February 02, 2004 at 11:40 AM
What geepherder is the best way to go. because they don't actually make 6x8 to 6.75 adapters...only 6x8 to 6.5 and 5.25 adapters. My only suggestion is (depending on the car you're doing this in) you may need to also add a spacer so the speaker isn't sitting way deep in the hole. I did this same thing with my 97 altime...I used quater inch (1/4th) MDF and made a plate and then another piece (in the shape of the speaker) to bring it out and away from the door a bit. I also suggest putting some silicone in between the MDF and the door (kind of like a gasket). That will give it a nice air and water tight seal. Good luck. ------------- Duane...
If you think you're confused, imagine how you feel.
Posted By: forbidden
Date Posted: February 02, 2004 at 1:49 PM
Coat the mdf with fibreglass resin (mixed with hardener of course) as well. If you have room for 1/2" mdf, use it, it will make a much more solid mount. Why the resin? because mdf will suck up moisture more than a wet / dry shop vac. If you have any type of moisture in your door, guarantee that it will find your nice new baffle board and destroy it worse than termites. Paint the baffle board blask after it is dry from the resin. In some cases they can be seen through the factory grills, the black paint makes them almost invisible. While your in the door, add some brown bread to the exterior door skin as well.
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: DYohn
Date Posted: February 02, 2004 at 2:56 PM
You could try a set of these and see if your mid will fit: https://www.mjmautoinnovations.com/sak68t65.htm
Posted By: jeffchilcott
Date Posted: February 02, 2004 at 4:03 PM
yo could also use cardboard and firberglass it for strength and then it will be thinner for clearence issues
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: customsuburb
Date Posted: February 02, 2004 at 7:00 PM
Look at this from Boston. It actually has a 6/12 woofer in a 5 X 7 enclosure. It probobly comes with rings to fit a 6 X 8 opening also. Also these are some rings to fit a 5 1/4 inch speaker in a 6 X 8 opening. https://www.crutchfield.com/cgi-bin/S-YImPuWXNW7s/ProdView.asp?s=0&c=11&g=103200&I=142SA68&o=m&a=1&cc=01&avf=Y https://www.bostonacoustics.com/ca_product.asp?Productid=264&CategoryID=14
