insulation in speaker boxes?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25797
Printed Date: April 22, 2026 at 5:09 PM
Topic: insulation in speaker boxes?
Posted By: erinh
Subject: insulation in speaker boxes?
Date Posted: February 03, 2004 at 7:06 PM
I'm about to install some 12'' subs. I built a box the size the makers recommended. My friends are telling me I should shove it full of some kind of insulation to make it sound better/louder. Is this true or should I not put anything in the box?
Posted By: mobiletoys2002
Date Posted: February 03, 2004 at 7:08 PM
in a sub box if you add poly fill u slow the waves down in the box making sub sound deeper as if it was in a bigger box play with the poly fill see if u like !
Posted By: forbidden
Date Posted: February 03, 2004 at 7:11 PM
Insulation = no
Polyfill = Yes
Polyfill = pillow stuffing material, available at Welfare Mart and other fine stores!
Posted By: Julian59
Date Posted: February 03, 2004 at 8:52 PM
They are sevrel things that adding Damping Material does to a sealed box.
A wise man once said
A. Compliance Increase. The use of low density high specific heat material will cause an increase in the acoustic compliance of the enclosure. This is the equivanlent to increasing the box size and can amount to as much volume increases of 15% to 25%.
B. Efficiency Increase.  Proper selection of the amount, type of material (fiber glass, dacron and long fiber wool) and the location of the material within the enclosure can cause an increase in efficiency by as much as 15%.
C. Mass Changes.   Filling material has the potential of changing the total moving mass of the system.
D.  Damping Losses.  iIf you pack filling material densely and close to the rear of the driver basket, frictional losses can be substantial.  Note: uncompressed loosely packed stuffing has no effect whatsoever in the effective volume of the enclosure.
Julian59
Be Smart Never Assume
Improvise Adapt and Over Come
Installer/Technician 20 years
Posted By: erinh
Date Posted: February 04, 2004 at 7:22 PM
julian so about howmuch should i stuff in there? just as much as i can get in?
they are for punch 12'' speakers that needed 1.25 cubic feet. i bought a 5lb box of poly fill earlier. should i try to fit all of it in the 2 boxes?
Posted By: chase84720
Date Posted: February 05, 2004 at 3:35 PM
Make sure it fills it but fits loosly.  put to much and it'll cause way more damage than good.   thats what i have gained from experiences with it.
chase
Posted By: DYohn
Date Posted: February 05, 2004 at 4:47 PM
Use about 1lb per cubic foot in a sealed enclosure.  Keep it away from the speaker's magnet structure as it can be burnt (and make your car smell bad.)
