good buy or not solo baric l7 15"
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25810
Printed Date: April 23, 2026 at 2:49 AM
Topic: good buy or not solo baric l7 15"
Posted By: skylark
Subject: good buy or not solo baric l7 15"
Date Posted: February 03, 2004 at 10:45 PM
I JUST BOUGHT two i7 15's off ebay they are dvc so im going to run them down to 1 ohm total question is do they bang like everybody says because i bought them at the spur of the moment after reading the reviews of the l7 on carreview im going to buy an vented box for 2 of savings lot com mdf box made just for the kickers and its vented so is it going to hit im going to use an audiobahn 1500 hct amp it pused my 4 15 inch audiobahns but im takeing them out of my car and going to put into my truck ...need to know asap .......thanks
------------- goingcrazyonsound
Posted By: sbrock
Date Posted: February 03, 2004 at 11:08 PM
I feel those are very good speakers if powered right and in the correct enclosure that to me make a huge difference but it sounds like you are on the right track with both
Posted By: skylark
Date Posted: February 03, 2004 at 11:20 PM
what about the amp and the enclosure i know its premade just for them kickers and the amp pushes out 2000 watts at one ohm
Posted By: skylark
Date Posted: February 03, 2004 at 11:22 PM
what about the enclosure and the amp i now the enclosure is made just for these subs and the amp pushes out 2000 watts at one ohm
Posted By: sbrock
Date Posted: February 03, 2004 at 11:27 PM
exactly what kind of vehicle are they going in
Posted By: skylark
Date Posted: February 03, 2004 at 11:36 PM
70 buick skylark droptop ------------- goingcrazyonsound
Posted By: sbrock
Date Posted: February 03, 2004 at 11:45 PM
In an older vehicle like that I would go with a completely custom enclosure maybe something ported into the vehicle to eliminate rattling but as far as your amp and subs I feel like it should really hit hard if installed properly
Posted By: skylark
Date Posted: February 04, 2004 at 12:07 AM
what would be better for more bass vented or sealed both boxes are made just for them subs ........need to know because i have had bandpass before and hated them but the vented one for the kicker looks sealed except for the vented part also the other box looks the same except its 100% sealed
Posted By: skylark
Date Posted: February 04, 2004 at 12:32 AM
anybody...................i need to know .......... help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
Posted By: customsuburb
Date Posted: February 04, 2004 at 3:41 PM
I have heard that kicker subs like sealed enclosures but thats your call. You dont neccessarily need a custom enclosure to make the car not rattle ,just break out the dynamat a little. I dont really like Audiobahn products but since you already bought it I guess you'll be ok. If you can buy an amp from JL or Rockford. They are better.
Posted By: forbidden
Date Posted: February 04, 2004 at 4:42 PM
The subs you have will work in either enclosure. They produce much better sound in the proper size sealed enclosure. This means a much more useable range of frequencies and better power handling in the lower frequencies (that a ported enclosure cannot play down to). Anyone can build a ported enclosure and call it to the spec for the sub but from my experience with subs in general, you can take any sub, model it on a box calibration program and specify the size and it will calculate the port length and width and number of ports. You can also change the size of the box and make it bigger or smaller and the program will change the port (s) accordingly. But at the end of the day if you take a computer designed box that is built for brand x sub at the minimum airspace possible and compare it to the same type of box with more airspace and the ports recalibrated to match, there is a huge difference in output and "sound quality" between the two. You have no way of knowing what kind of enclosure this prefab,built to spec box really is. These subs work best in a sealed box or with a large, much larger ported enclosure. True the ported will play louder, but any two 15" drivers are going to play loud, I just happen to like the sound and performance of them in a sealed box. If you go with ported, a subsonic filter is highly recommended to help protect the subs. ------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: jeffchilcott
Date Posted: February 04, 2004 at 5:18 PM
Win Isd is a type of program that forbidden is talking about you can get it free on the net, i have fooled with those subs in vented and sealed. it is really hard to keep alot of clarity in vented boxes but it can be acomplished with a very clean amp, and the box to exact specs
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: sbrock
Date Posted: February 04, 2004 at 5:52 PM
I don't think just anyone can build a ported box but I can tell you that there will be a noticeable difference if you go ported instead of sealed and I know this for a fact but the very best thing to do is to call Kicker and ask them what they suggest
Date Posted: February 04, 2004 at 5:58 PM
I don't agree, Kicker cannot tell me what I prefer. Build the sealed box first, if you like it leave it alone, if you don't, then build the ported enclosure, to spec. Now you can compare the two and see the drastic differences in output and type of response. I do agree that not anyone can build a box, some people can, others fail miserably.
Posted By: sbrock
Date Posted: February 04, 2004 at 6:08 PM
You right they can't tell what you prefer what I meant was they can tell you who to get the most out of their subs also I agree about some people failing miserably, but everyone has to start somewhere
