amp for 2 kicker s12l7?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25948
Printed Date: April 19, 2026 at 7:08 PM
Topic: amp for 2 kicker s12l7?
Posted By: dtownhustla
Subject: amp for 2 kicker s12l7?
Date Posted: February 06, 2004 at 11:37 AM
i have 2 L7 12-inch dual 2ohm subs
maximum recomended amp power(watts peak)-------1500
maximum recomended amp power(watts rms)--------750
what would be a good amp for them i was thinking bout the mtx 1501 D
i want them to bump all they can       can anyone help ???
Date Posted: February 06, 2004 at 11:40 AM
oohh and do they sound good on sealed boxes what would be a good type of box
Posted By: EzekialPhoenix
Date Posted: February 06, 2004 at 3:14 PM
Well, I have two of them in a small sealed box and I enjoy them.  They can definitely be ported, but I think the volume requirements for two L7 12"s is enormous.  If you don't mind losing the space, and want it really f' ing loud, that would be the way to go.  As of now, mine get extremely loud in a small sealed enclosure (each chamber about 1 cubic foot after displacement) and sound pretty good (I'm still messing with the gain).  With regard to an amp choice, my L7's are dual 4 ohm so I am running them to a Crossfire VR1000D at 1 ohm.  I think the MTX would be a fine choice.  I think Rockford makes an amp that puts out about 1500 watts at 2 ohms.  Really any amp that puts out 1500 watts at 2 ohms would be prefectly fine.
I be tossin and flossin, my style is awesome. Causin' more family feuds than Richard Dawson.
Posted By: gregfocker77521
Date Posted: February 06, 2004 at 7:18 PM
I have 2 planet audio amps TT850.  You can hook up one sub to each amp wired at 1ohm. The amp puts out 850 watts at 1ohm. Let me know if your intrested.
luissegovia@earthlink.net
Posted By: customsuburb
Date Posted: February 06, 2004 at 7:39 PM
Look at JL Audios 1000/1 if you have some cash to spend you wont be dissapointed with this amp. It outputs the same amount of power from 1.5 to 4 ohms which can come in real handy. Otherwise go with a Rockford Fosgate amp. Look at their Power 1501bd. at 2 ohms it outputs 1500 watts RMS. If you do go with multiple amps you should carefully match each amps output so they are all the same to avoid cancellation.
