Best way to power/wire 4 Alpine Type R’s
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26078
Printed Date: April 01, 2026 at 3:48 AM
Topic: Best way to power/wire 4 Alpine Type R’s
Posted By: xpr626
Subject: Best way to power/wire 4 Alpine Type R’s
Date Posted: February 08, 2004 at 6:06 PM
Whats the best way to power / and wire (4) Alpine Type R 10" Subs in a dodge stealth. Thanks! }:)
Posted By: the Finn
Date Posted: February 08, 2004 at 6:34 PM
Which voicecoil are they? single or dual 4 ohm? By power do you mean what amp to use? or are you just wondering how to wire them for the most power out of your amp? If so, what kind of amp are you using?
let me know and I will give you some ideas/advice! 4 of those should rock in that little car.
~Cory
Car Concepts SLC
Alpine F#1Status Certified
Posted By: Teamrf
Date Posted: February 08, 2004 at 7:28 PM
Get some Alpine amps to go with them...Looks good. posted_image
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: Alpine Guy
Date Posted: February 08, 2004 at 9:17 PM
swr-1041d or swr-1021d ??    ie.  Dual 4 ohm voice coil or dual 2 ohm voice coil??
If we know that, then we can help.
Didn't you get a manual with the subs? it gives you all the ways to wire them.
Posted By: Ketel22
Date Posted: February 08, 2004 at 9:23 PM
i believe the type R's come in only dvc 2ohm or dvc 4ohm models. in which case you would need to run parallel/series to get either a 4ohm/1ohm with the 2ohm dvc or a 2ohm with the 4ohm dvc i believe. you will need an amp stable at 1,2 or 4ohms (dependent on setup) that puts out around 1200wrms.
Quad L Handyman services
Posted By: xpr626
Date Posted: February 16, 2004 at 8:36 PM
swr-1041d...best amp rec?
Posted By: Ketel22
Date Posted: February 16, 2004 at 9:22 PM
jbl 1200.1 would work good
Date Posted: February 16, 2004 at 11:37 PM
I would personally go with the alpine mrd-m1000.  My co worker has this set up and the windshield of his mazda b2200 shatterd into a million pieces.   So if you go this rout,,,be shure you carry ear plugs.
Posted By: forbidden
Date Posted: February 17, 2004 at 12:45 PM
Dodge stealth's do not exactly have the worlds biggest alternator as well, 4 subs on max draw to a matched amp is going to cause alternator issues in this vehicle, and a cap is just going to worsen it in most cases. As the vehicle is actually a Mitsubishi I would have a look for a high output alternator, I'm not an alternator man but someone on here will point you in the right direction.
Posted By: jeffchilcott
Date Posted: February 17, 2004 at 5:21 PM
Go with a good 1 ohm stable amp and pound the hell out of them,   look for an orion, zapco, phoenix to really supply the power to all subs at 1 ohm
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Date Posted: February 17, 2004 at 10:28 PM
stay away from phoenix, they have the highest warranty return rate of the top brands.
Posted By: xpr626
Date Posted: February 20, 2004 at 1:15 PM
How many amp alternator do you rec. I can get a 170 it currently has a 110 and I will have a yellow top optima in da back.
Date Posted: February 20, 2004 at 4:35 PM
if you can get a 170, get the 170.   The 110 will do, but you wont get the full potential, especially if you have heat or ac on, , or if you have head lights on.
Posted By: 94bonny
Date Posted: February 26, 2004 at 8:32 PM
i kno this is off topic, but are you 100% positive that his Dodge stealth(an american car) is actually a mitsubishi(a japanese car)?
Date Posted: February 26, 2004 at 10:06 PM
mitsubishi  motor, i have seen them in chev vans too.
