Install Pics - Post Pics Of Your Install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26147
Printed Date: March 30, 2026 at 5:47 PM
Topic: Install Pics - Post Pics Of Your Install
Posted By: MBZ oe
Subject: Install Pics - Post Pics Of Your Install
Date Posted: February 09, 2004 at 2:09 PM
Here's a pic of the finished trunk. I may make a door that opens with electric actuators to open. The box is mounted on heavy duty hinges with actuators to lift rear for spare tire access. Amps are Kicker, 1200.1 for subs and 300.4 for highs and mids. Head will be alpine CDA-7995 or Eclipse and is Sony right now. Capacitor is VooDoo 3F Rackmount. 0ga wiring with gold and platinum pro connections/distribution. Amp Rack is designed to be layered so I can eventually mount 2 more 1200.1's on the next amp rack layer so there will be one amp per sub. Three runs of 0ga are run to trunk and alternator is beefed with 0ga as well. Dynamat X-Treme was installed in entire car.
posted_image
BOOM, BOOM, BOOM BOOM....
Posted By: MBZ oe
Date Posted: February 09, 2004 at 2:12 PM
Now the pic is there.
Posted By: the12volt
Date Posted: February 09, 2004 at 2:15 PM
You need to make sure you do not have file extensions hidden for known file types or make sure the file extension is included in the path to your image when you upload it...   https://www.the12volt.com/installbay/forum_posts.asp?tid=21746&PN=1&fid=12&PR=3
posted_image the12volt • Support the12volt.com
Posted By: MBZ oe
Date Posted: February 09, 2004 at 8:10 PM
Here is my battery compartment:
posted_image
