2 amp install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26402
Printed Date: April 04, 2026 at 12:56 AM
Topic: 2 amp install
Posted By: pyglion84
Subject: 2 amp install
Date Posted: February 13, 2004 at 2:41 PM
Ok i need some help. i have a kenwood 2 channel 350watt amp and a rockford 301s amp. the fosgate amp is powering my 12inch jl audio w6 and i havent hooked up the kenwood yet, but i want to hook it up to 2 6x9s and the front door speakers in a 2000 honda civic ex. it does have a component system. i will upgrade those speakers to mb quart and also mb quart 6x9s in the rear. i have a amp kit for the new amp and also a distro block. first is it possible to run all speakers off of the kenwood or do i NEED a 4 channel. and how do we hook up 2 amps to car. i have a alpine cd player with sub pre outs and another set of preouts. sorry for the long story but i just wanted to make sure i didnt leave anything out. let me know what i should do
Brandon
Posted By: forbidden
Date Posted: February 13, 2004 at 3:38 PM
Your best bet is a 4 channel amp. All speakers can be run off the Kenmore but it is not recommended. For now use it to power the front speakers only and leave the Alpine cd player to run the rears. To hook the 2 amps up in the car is simple. The amplifiers can share both power and remote on wires. This means that the distribution block is used to power both amplifiers for +12v. The remote on lead is connected to one amp, then run another wire from that same connection to the other amp. The ground wires should be connected at the same spot is possible. The fuse at the battery should be the same size or larger as the combined value of the fuses in the amps. Make sure you run a minimum of 4 gauge power wire to the distribution block and upgrade the battery to chassis ground with 4 gauge as well.
Date Posted: February 13, 2004 at 3:45 PM
ok thanks a lot...also to run my front speakers off of the amp, would i disconnect it from the cd player and just run it straight to the amp. my alpine cd player says it puts out 60x4 so it should be more then enough to power the 6x9s by themselves right? and again thanks for your help
Brandon
Date Posted: February 13, 2004 at 4:29 PM
Yes you are correct with the wiring situation.Your Alpine amp will make 60w x4 if it get struck by Lightning, ignore that wattage claim, it has enough power to run the rear speakers just fine.
Date Posted: February 13, 2004 at 10:02 PM
ok man thanks a lot...i really appreciate it!!!
Brandon
Posted By: BangBang
Date Posted: February 14, 2004 at 12:00 AM
yeah sure no problem help me out with my situation plz lolz
still stuck on installine 2 amps
i went to radio shack and a distribution block is 19.99 + tax wtf is that? then i gotta buy two 60 amp fuse $3.99 + tax wtf is that lolz
then i have to buy RCA Y splitter. its like $4.99 + 5 for shipping and handling (buying off of ebay).  then i have to buy 8 guage wires about 10 ft. thats about $2.50per/feet. wtf is taht all about lolz
do i need to buy a distribution block for my ground wires?
Posted By: Clean Install
Date Posted: February 14, 2004 at 1:43 AM
lol no
If we learn from each success and
each failure, then we can improve ourselves
Date Posted: February 14, 2004 at 8:38 AM
no but you can also buy a distro block of of ebay...that is where i bought mine
Brandon
Posted By: BangBang
Date Posted: February 14, 2004 at 11:57 AM
i checked it off of ebay its going for around $12.99 + shippng and handling like $4.99
thats about $19 might as well buy 1 from radio shack, that way i save time?
or do u know where i can get a good quality but for low price
pleaze post the site thanx
Date Posted: February 14, 2004 at 3:13 PM
try this one...https://cgi.ebay.com/dll?ViewItem&item=3078088320&category=50550
Brandon
Posted By: spl_enterprise
Date Posted: February 14, 2004 at 11:06 PM
distro blocks are cheap. figure out what style fuse you want, agu seems to be the most popular, and look on ebay. you dont have to buy a phoenix gold or a stinger if you dont have the money but they are both nice.
Pete - SPL Enterprise Inc.
Date Posted: February 15, 2004 at 1:29 AM
ok when i run my wires for my front speakers, cant i cut the speaker wires from the factory harness and splice those and run it to the amp instead of running from the door to the amp. and also. i have a factory component system which i plan to switch with 6.5 mb quart component. i would only have to run wire from the 6.5 speaker to the amp instead of having to run a wire from the tweeter to the amp and run one from the 6.5 to the amp right? i have never installed or worked with a component but i imagine they are connected together by a crossover?? and thanks for all the help so far!!!
Brandon
