Constant Hiss in audio System
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26431
Printed Date: April 03, 2026 at 5:15 PM
Topic: Constant Hiss in audio System
Posted By: Birdman
Subject: Constant Hiss in audio System
Date Posted: February 13, 2004 at 11:32 PM
Hello Everyone,
This is my very first post to this forum.  I've been reading a lot on here and it seems everyone knows a greta deal about car audio, so maybe somone can help me with my problem.
I have been a car audio enthusiast for over 13 years, so I've installed my share of headunits, amps, capacitors, batteries, etc.  This particular problem, however, really has me stumped.
I just purchased an Eclipse CD8443 headunit.  While this unit has active built-in amplifiers, I am not using those outputs.  The rest of my audio system consists of the following:
* JL Audio 500/1 Amplifier
* JL Audio 300/4 Amplifier
* JL Audio 12W6v2 sub (powered by the 500/1)
* Polk Momo 6.5" components (powered by the 300/4)
* JL Audio XR650-CXi 6.5" Coaxials (powered by the 300/4)
* Monster MicroXLN RCAs for FRONT, REAR, and SUB
* #4 AWG run from battery to distribution block in rear
* #8 AWG run to 500/1 and 300/4
* #8 AWG grounds to each amp
Ever since I have installed my Eclipse deck, I have a continuous HISS in the backround.  Here is what I do:
1) Car is OFF (engine noise is NOT an issue)
2) Power cables and RCAs are on OPPOSITE sides of the car
3) I turn on the unit
4) I put in a CD
5) I put the CD on PAUSE
6) voila!.......continuous HISS!!!!
The hiss is ALWAYS present, but most noticeable when there is no audio coming through the speakers.
The hiss does NOT seem to increase or decrease with volume level changes
If I put the volume to its lowest level of ZERO (i.e. the preamp outs are OFF) then there is NO HISS
If I pull the RCAs out of the amp, there is NO HISS
I installed some RCA inline Ground Loop Isolators to see if that helped........STILL HISS
Do I have a problem with my Eclipse deck?  Do you think my ground is bad on my Eclipse deck?
Any thoughts would be GREATLY appreciated!
Thanks,
Scott
Posted By: Birdman
Date Posted: February 14, 2004 at 12:04 AM
ttt
Posted By: BangBang
Date Posted: February 14, 2004 at 12:13 AM
that happend to me as well.
what you might want to do is check the settings taht you have on the amps
for example you know those lil "knobs" on the amp, some may be to high or to low.
also one of your hot wires could have a cut while its going connected from the amp to the battery. check the entire wire make sure its not near sharp edges.
have any more problems let me know i'll see if i can research more and let you know wats going on.
Posted By: thapimpfromchi
Date Posted: February 14, 2004 at 1:07 AM
do you mean, a hiss, similar to that found on old cassettes, before the lovely Dolby B hiss reduction technology came out.
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
Posted By: devilsquid
Date Posted: February 14, 2004 at 1:12 AM
could be ground...could be bad rca cables...i never used eclipse personally, so i cant say about the deck but what size ground do you have on the battery itself?  just an idea...
Posted By: Birdman
Date Posted: February 14, 2004 at 5:12 AM
Yes, that is a good comparative sound.
Posted By: Birdman
Date Posted: February 14, 2004 at 5:14 AM
#4 AWG + #8 AWG (2 wires) from the Stinger 1000 battery to the car's chassis.
Posted By: DYohn
Date Posted: February 14, 2004 at 9:51 AM
Assuming you have no ground loops, most likely you have a level mis-match.  Your amplifiers gain is set incorrectly.  Check the very good tutorial on the JL Audio web site and re-set your gains.
Posted By: Birdman
Date Posted: February 14, 2004 at 12:10 PM
So much for reading manuals!
OK, these JL Audio amps are very creative beasts and I'm posting my solution to my HISS problem so everyone else can learn from this.
Basically, DYohn was correct.....it was the sensitivity adjustment. (thanks for poking me to look at this yet again, DYohn!)
That being said, however, I must learn to go with my GUT feel more than simple measurements.  JL Audio describes very nicely how to go about adjusting the sensitivity of these amps to insure that 17.3 VAC is occurring at the amps' outputs when a 1 kHz non-attenuated signal is pumped in from a CD in your headunit.
I did everything they said...
1) Turned off LOUDNESS BUTTON
2) Set BASS at 0
3) Set TREBLE at 0
4) Set all EQ settings at 0
5) Set all crossover points to PASS-thru
6) Set Deck volume to 3/4 (level 60 of 80 on my unit)
7) Used a Bass Mekanik CD with a 1kHz continuous tone at 0 dB
There procedure states to set the input voltage switch to LOW (there is a LOW and a HIGH setting) and turn the gain of the amp all the way down.  Then I am to turn the amps' gain UP until the AC voltage at the speaker terminals is 17.3V (for a 4-ohm load).
So, I do this.  I get the 17.3 VAC when the gain is at about 1/3 of maximum.
For giggles, I also tried seeing where the gain knob would need to be to achieve 17.3 VAC when the input switch was set to HIGH....the gain knob needed to be at 2/3+ to achieve this voltage output.
Therefore, the obvious choice from these measurements would be the LOW input selection........[b]WRONG![/b]   This is where I got a LOT of my HISS from.
My gut TOLD me to use the HIGH setting b/c the deck has 8V preouts, but that isn't the way JL says to determine the settings.
Anyway, I went BACK to setting the input to HIGH and I set my gains to 1/3+ (not the 2/3+ value!) and I have greatly reduced HISS and a pretty good output.
If I turn the gain up to 1/2 or above, I really start to get some unwanted noise from the amp.....very odd, but at least I have found a reasonably clean and powerful setting.
Posted By: DYohn
Date Posted: February 14, 2004 at 1:02 PM
I believe your gut is correct on this one.  IIRC, the Low setting is designed for 2-4 V pre-outs and the High is for 4-8 V.  Sounds like you have solved your problem!
