1993 Buick LeSabre - Too young to go bald
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26508
Printed Date: March 17, 2026 at 7:52 PM
Topic: 1993 Buick LeSabre - Too young to go bald
Posted By: nlauver1978
Subject: 1993 Buick LeSabre - Too young to go bald
Date Posted: February 15, 2004 at 10:00 AM
The Head Unit in my 1993 Buick LeSabre has stopped working. I've checked it. I think the Euphemism is, 'Stick a fork in it.'
So I bought a Sony CDX-M630 to replace it, the mounting kit, but could not find a wiring adaptor ANYWHERE and I need to get my car put back together today. So I hard wired it. (Please don't hit me.) EVERYTHING WORKS GREAT. Just no sound. From any speaker. Reset the head unit. No Sound. Faded, balanced, bassed and trebled. No sound. Like I said, it all works, just no sound.
On an odd note, the head unit was a DELCO-LOC II Dated 1996. So I assume this was not this car's first head unit.
I'm going to check all my wiring. If you have any suggestions, I'd appreciate them.
Thanks,
Nate.
-Nathan
Posted By: DYohn
Date Posted: February 15, 2004 at 12:19 PM
Check to see if your car had external amps.  Use a battery to check the speaker leads and listen for each speaker to "pop" or make noise when you connect a battery to the leads.  If ther speakers do not respond, you most likely have a factory amp somewhere.  You may have to run new speaker wires if you cannot find the amp and bypass it.  I will also predict that if you are still using the factory speakers you will soon need to replace them, as the new HU will have 5 to 10 times the amplifier power of the OEM unit, and the factory speakers will sound like crap (until they burn out completely.)
