what is better ported or sealed
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26604
Printed Date: March 21, 2026 at 5:42 PM
Topic: what is better ported or sealed
Posted By: ginuwine
Subject: what is better ported or sealed
Date Posted: February 16, 2004 at 9:35 PM
i was gonna make my box ported now a guy told me at the car audio place i was at tonight that sealed would be better for my car i have a 2002 mercury cougar my subs are 2 12" sony xplods 1200watts 350rms my amp is a rockford fosgate 301m mono 900watts max 343 on the birth sheet rms
what will make my subs the loudest ported or sealed i have the box right now built to specs for ported but i will change it to specs of sealed if it will make them better
i started the box today at 10am siliconed i just need to cut holes for my subs i wanna make sure i do this right the first time so any help would be great ok thanks in advance
Posted By: auex
Date Posted: February 16, 2004 at 10:53 PM
This is a tricky question with out more details. First ported will be louder then sealed, but sealed will sound better. Ported boxes require more airspace then sealed so don't go and port a pre-fab box or a box that is too small. Also ported boxes will sound the best and the loudest if you use the manufacturer's recommendations, or you use a program to get the correct airspace and port dimensions.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: forbidden
Date Posted: February 17, 2004 at 12:28 PM
How big have you made this box? If you are just starting in car audio, your safest bet it to leave the box sealed. Make yourself a second ported box, to the recommendations of the manufacturer (or what someone here can provide for you). This may be an extra hassle for you and it little more cashola to lay out, but you will learn from this, and this is something that we cannot teach you on a confuser.
Posted By: jeffchilcott
Date Posted: February 17, 2004 at 5:26 PM
try winisd, i mainly only build vented boxes, as you can achieve a cleaner sound with vents then with round ports, i also think that you get a better frequency increase with vents vs. round ports.   you dont get drastic increases in bass with minimal increase in volume. again look into a freeware program like winisd or blublux..both are availible online for free
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
