Kicker L5 15" enclosure
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26928
Printed Date: April 23, 2026 at 4:21 PM
Topic: Kicker L5 15" enclosure
Posted By: spl IROc-z
Subject: Kicker L5 15" enclosure
Date Posted: February 21, 2004 at 7:42 PM
Hey I need some help with an enclosure. I have installed 2 Kicker L5 15's in the hatch of a 88 IROC-Z. They are facing straight up in a 3 cu.ft sealed box. I am pushing them with a Audiobahn A2200HCX. This amp is 1600w x 1 rms @1 ohm. My problem is that the subs dont play the upper frequencys worth a crap. The lows are crazy, but this limits the musical ability. Does anybody have experience with these subs? Should my box be a  little bigger?. The Kicker manual says 1.5-6.0 cu. ft. That makes it hard to get it right. I want bass that makes your hair stand up, but still want to be able to feel like i'm front row at a AC/DC concert. If it helps I have a Pioneer DEH7500 head unit, a Audiobahn  line driver, a Audiobahn 2150 amp,(inside speakers) and Audiobahn 4x6's and 6x9's. Thanks for the help!
Posted By: forbidden
Date Posted: February 21, 2004 at 7:54 PM
The 15's are designed for the big bad bottom end, not the upper frequencies. A 10" sub can play the same lows as a 15", just not with the same authority but they do a much better job at producing the upper frequencies. By making the box a little bigger you will actually increase the bottom end capabilities and lower the power handling of the speakers. You best bet might be a pair of 10" drivers in a sealed box and bandpassed to run between approx 70-120hz, this means another amp and a crossover that has bandpass capabilites.
Date Posted: February 21, 2004 at 8:33 PM
So is there no way to make them more musical? I had 2 Orion XTR Pro 15's on a Rockford Power 800 and they pounded like crazy....and you could listen to everyday music on them as well. I was hoping that a bigger box would help eliminate this problem. Thanks so much for the info.
Posted By: customsuburb
Date Posted: February 21, 2004 at 8:44 PM
Every sub is different. You could try using an AudioControl Epicenter. These are supposed to improve your bass response(it's not a bass boost, that makes it boom more, it's like a bass improver). I don't know how much it would improve your system though.
Epic 160
Epicenter
Posted By: bryceyaworsky
Date Posted: February 22, 2004 at 3:38 AM
The Kicker L5's and L7's are simply not designed for high-frequency bass, instead they're made for that "crazy low-end".  About the only thing you can do with them is either make a vented or band-pass box with a high target fq or better yet, get some mid-bass speakers.
Posted By: Ravendarat
Date Posted: February 23, 2004 at 3:57 PM
Try making you box a little smaller by using blocks of wood to take away air space. If you are looking fo quicker, more musical response , you probally need a smaller box. I have used these subs before but I havent heard of anyone trying to use them for anything besides big boomy bass
