installing XM Radio
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26952
Printed Date: April 23, 2026 at 12:55 AM
Topic: installing XM Radio
Posted By: jtfrog
Subject: installing XM Radio
Date Posted: February 22, 2004 at 11:16 AM
I just installed XM radio on my girl freinds jette. I had to use the FM modular. A problem has now come up. The radio and the XM mow only work in the accesory postion. When you start the car or turn the key to the on positon it does not work. I f I turn the key as if i am going to start the car it will work. Also on Jettas when you turn the key of the radio would still play until you take out the key, not any more. Please help. I was thinking that maybe the ignition switch has gone out by some freak accident
Posted By: Teamrf
Date Posted: February 22, 2004 at 1:14 PM
Make sure you used the right constant wire
------------- ~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: jtfrog
Date Posted: February 22, 2004 at 4:30 PM
What do youmean by constant wire. There are two hot wires. One from the ignition wich is on when in accessory and the other is battery power
------------- jtfrog
Posted By: zeiden
Date Posted: February 22, 2004 at 4:56 PM
Sounds to me like you are using the wrong power line to supply your xm receiver. Your xm receiver comes with a ground (black wire) and a yellow (constant power wire). Make sure that you have connected the other end of this yellow wire to your car's yellow wire. If you still have doubts, you can always buy a 12 volt power indicator. This way you can make sure that power is flowing while your key is in any possition.
Posted By: jtfrog
Date Posted: February 22, 2004 at 6:19 PM
I just tried doing that and the same thing. I am starting to beleive it is the ignition because the radio is acting the same as the XM and it never did before.
