Installing an amp in a 1996 Mercury Sable
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26960
Printed Date: April 22, 2026 at 8:55 PM
Topic: Installing an amp in a 1996 Mercury Sable
Posted By: lgaddy
Subject: Installing an amp in a 1996 Mercury Sable
Date Posted: February 22, 2004 at 1:58 PM
I have a 1996 mercury sable and I just purchased a MTX Thunder 4202 amplifier from my friend and a subwoofer.  I am a complete novice in the area of installations, but I am willing to learn.  How should I go about  doing this?  There looks to be a connection right under the steering wheel that I would connect a harness to but I am not sure.  I already have a 10-disc changer with a fm modulator hooked up to the radio that I paid someone to do.  I would now like to connect the amp and subwoofer.  Any help would be appreciated.
Posted By: customsuburb
Date Posted: February 22, 2004 at 2:08 PM
Look at this amp kit from streetwires to connect everything: https://www.crutchfield.com/S-DUoNxWkFsiU/cgi-bin/ProdView.asp?s=0&c=11&g=711&I=211PS8RI&o=m&a=0&cc=01&avf=N You will need an LOC also which takes a speaker level signal(it ties into a set of your speaker leads to get its signal) and turns it into a preamp output for your amp. Dont connect power to the harness under your dash. You need to go directly to your battery post with the + power cable and the ground cable needs to be grounded no more then 3 feet away from the amp on clean metal. If you need more details ask.
Posted By: lgaddy
Date Posted: February 22, 2004 at 3:52 PM
Thanks customsuburd, he gave me most of those wires, I think I need the LOC(is it the same as the speaker level to line level converter ?)  How do I tie that into my speaker leads? Is that where the harness under the dash comes into play?  I really want to understand this stuff.
