94’ Camaro removal/install of stock unit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27087
Printed Date: March 31, 2026 at 7:02 AM
Topic: 94’ Camaro removal/install of stock unit
Posted By: Big_Josh
Subject: 94’ Camaro removal/install of stock unit
Date Posted: February 23, 2004 at 9:59 PM
I've currently got a cheap Sony head unit in my car. I bought it this way but can't for the life of me figure out how to remove either the dash or just the housing around the unit. I've taken off the bolts that are right by the unit, even the ones in the glove box, but it's just not budging. I've also taken out the one screw inside the little compartment under the unit and the 2 inside the arm rest, still nothing. How in the heck do I get it off? Also I've noticed that you can move the arm rest console easy once those bolts are removed. Is this a good place to run my 2 gauge power and remote wires? I've turned my T-tops compartment into a single huge box for 2 15 Orion H2's. But I can't get my KV911 in the dash. Can someone please help me in either a wiring diagram and or instructions on how to remove the unit? Thanks so much and it sucks big time when you've got all the stuff but can't listen to it. HELPPPPPPPPPPPPPPP!
Posted By: BNLUIS
Date Posted: February 23, 2004 at 10:05 PM
your lucky day, full instuctions on removal with pics. GOOD LUCK
follow link
https://www.carstereohelp.com/stereoremovalChevyCamaro2.htm
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Posted By: Big_Josh
Date Posted: February 25, 2004 at 10:35 PM
Luis,
   You seriously are the bomb!! Big time life saver and with  pics to go along with it. posted_image Couldn't ask for a better way to do it, I'm all about visual learning and those pics couldn't explain it any better. Seriously I thank you and I'll be donating some $$$$ by manana!!!!! Thanks again
