Bass cutting out intermittently
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27399
Printed Date: May 15, 2026 at 2:23 AM
Topic: Bass cutting out intermittently
Posted By: chriswallace187
Subject: Bass cutting out intermittently
Date Posted: February 28, 2004 at 2:35 PM
Ok here's the problem folks; my car audio troubleshooting skills have failed me here. I have an '02 Sunfire with the following components - Pioneer DEH-P7400MP h.u., Monsoon factory amp powering factory speakers, MTX Thunder4202 powering a Coustic BP104 sub.
Here's the problem - I've had this system for about a year and a half, and within the past 2 weeks the sub has started intermittently cutting out. It will cut out for a few seconds, then back on, and then off again. The ground and power supplies are fine, the LED on the amp doesn't go out when the sub cuts out, and all the connections are good. The amp's not the least bit hot when it does this; the only thing that is remotely hot is the head unit.
Any ideas? Thanks in advance.
Posted By: DYohn
Date Posted: February 28, 2004 at 3:41 PM
Could simply be the sub is in the process of failing. They do wear out over time, especially if they are pushed hard.
