how to check cap with voltmeter?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27545
Printed Date: May 17, 2026 at 12:02 AM
Topic: how to check cap with voltmeter?
Posted By: 00neon
Subject: how to check cap with voltmeter?
Date Posted: March 01, 2004 at 10:12 PM
how would i go about checking my cap to see if it is working?  i have a voltmeter.....do i just put in on the + and - or should i go+ to ground??? any help greatly appreciated
1 JL 12 w3 D4
1 MTX 421 D Monoblock
1 Sony Xplod 75x4
Front: Alpine SPX-177A
Rear: JL audio VR690-CXI
Posted By: speedwayaudio1
Date Posted: March 01, 2004 at 11:27 PM
take the cap off line, be careful not to ground the + side. put your voltmeter + to+ and -to - If it is woking it should  show 12volts and hold a charge until discharged. once again caps can be fire works show if you ground that  + side.
Big Dave
Posted By: DYohn
Date Posted: March 02, 2004 at 8:44 AM
Be very careful handling a charged capacitor, as they can hurt you.  I have a scar across my right elbow where one discharged through me when I brushed against it years ago.  Burned the skin right off it did.  And if you connect a meter across charged terminals in ohms or current mode, the meter can blow up in your hand.  Why do you think it's not working?
Posted By: 00neon
Date Posted: March 02, 2004 at 9:37 AM
DYohn] wrote:
nbsp; Why do you think it's not working?
because the led light is not lighting up, i just want to check voltage to make sure its working before i go taking it back to the person i bought it from
1 JL 12 w3 D4
1 Sony Xplod 75x4
