Inverted sub wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=2758
Printed Date: March 30, 2026 at 1:11 AM
Topic: Inverted sub wiring
Posted By: dBsounds
Subject: Inverted sub wiring
Date Posted: August 13, 2002 at 4:10 PM
I had a brain freeze and this is a rather simple question, I hope!  I know when mounting one sub normally and another sub inverted, you must wire one of the subs (usually the inverted one) "out of phase" so the mechanical actions of both subs are the same.  My question is: When wiring two subs inverted in a sealed box with seperate chambers, do you wire both subs normally or out of phase?  Both subs are AudioBahn's AW1206Q DVC.  Thanks for any help.
dBsounds-Feel the Intensity
Posted By: Velocity Motors
Date Posted: August 14, 2002 at 12:46 AM
Wire them normally like they were both in the box.
Posted By: dBsounds
Date Posted: August 14, 2002 at 7:19 AM
Thanks Jeff - I appreciate the knock on the ol noggin.
Les
Date Posted: August 14, 2002 at 7:51 AM
Always here to kick some sense into someone posted_image
