Getting rafio out of 96 Integra
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27605
Printed Date: April 02, 2026 at 2:06 AM
Topic: Getting rafio out of 96 Integra
Posted By: foodang
Subject: Getting rafio out of 96 Integra
Date Posted: March 02, 2004 at 7:08 PM
im trying to put an after market radio in my freinds 96 acura integra. I cant seem to figure out how to get the stock radio out. Any one have past experiance with this model? how did you get the radio out
Posted By: forbidden
Date Posted: March 02, 2004 at 7:13 PM
Look up, way up under the back of the radio from down under the dash, see if you can see two bolts, one on either side of the back of the deck, get those out and you are off to the races.
Posted By: mobile1
Date Posted: March 02, 2004 at 7:43 PM
If you remove the screws around the center counsole and slide the counsole back, you'll have better access at  the 2 screws. They should be 8mm holding the radio in.
Posted By: auex
Date Posted: March 02, 2004 at 7:49 PM
Sometimes you can pull it out, hard.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Sweekster
Date Posted: March 02, 2004 at 11:30 PM
Here's a link that should help.
Duane...
If you think you're confused, imagine how you feel.   posted_image
