tweeters
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=2769
Printed Date: March 29, 2026 at 8:24 PM
Topic: tweeters
Posted By: DjRDifacs
Subject: tweeters
Date Posted: August 14, 2002 at 1:03 AM
when hooking up tweeters and the front speakers to an amp,  and wire 'em in parallel, will the amp see a 2 ohm load?  and if i hook 'em up to the front speakers without the amp, will the deck see a 2 ohm load?
Posted By: Velocity Motors
Date Posted: August 14, 2002 at 1:25 AM
You can not do this to a set of tweeters. The tweets will be dust within 5 minutes because you will ge running full range into them from the amps crossover. Tweeters are only meant to be run as 4 ohms or higher.
Date Posted: August 14, 2002 at 1:34 AM
the tweeters have little crossovers  .....so how would i hook up separate tweeters to my front?
