JL Audio 10 w3
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27745
Printed Date: April 05, 2026 at 4:27 PM
Topic: JL Audio 10 w3
Posted By: blackmagik
Subject: JL Audio 10 w3
Date Posted: March 04, 2004 at 7:02 PM
I have a question regarding my sub, I just nticed that one of the wires has pulled out of the voice coil but since it is a dual voice coil set up can it still be used and functio properly or should i just throw it away.
Posted By: harvey1959
Date Posted: March 05, 2004 at 4:39 AM
Try it and see what happens. You will now have a SVC sub.
------------- Harv
Posted By: pioneer86
Date Posted: March 07, 2004 at 5:50 PM
If you've got the extra money, I would go out and buy a new sub. If you just hook one coil up, you will risk burning your amp out if that extra wire shorts out. This will happen especially if you don't have it properly fused. Even when you've just got one coil hooked up, the other coil is still getting the same amount of power because the sub is moving and creating the power in the extra coil. If you must use the messed up sub, cut the broken wires completely off so there is no chance of it shorting out. Then, you're just stuck with a SVC sub and its life has been dramatically shortened. BUT, it will work.
