2 ohms
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27935
Printed Date: April 10, 2026 at 2:33 AM
Topic: 2 ohms
Posted By: flashalex
Subject: 2 ohms
Date Posted: March 07, 2004 at 11:02 PM
Is there a way to wire 2 of these https://www.audio-warehouse.com/web/mdl/AW1200Q/detail.asp into two ohms on a 2 channel amp?
Posted By: forbidden
Date Posted: March 07, 2004 at 11:27 PM
No, a pair of these subs will hit a load of 1 ohm, 4 ohm or 16 ohms. See the other thread you started for my answer on how to wire the subs to your amp.
Posted By: thapimpfromchi
Date Posted: March 08, 2004 at 1:26 AM
wait a sec. What do u mean on a 2 channel amp? Are you going to run one sub to one channel? If thats the case, then yes, you can get it to 2 ohms, otherwise Rob is right.
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
Posted By: wvsquirrel
Date Posted: March 08, 2004 at 2:06 AM
(2) 4ohm DVC's, sure you can wire them to a 2-channel amp as long as the amp is 2ohm Stereo and/or 4ohm Mono stable.
You can wire 1 sub per channel by wiring each sub in Parallel for a 2ohm total load per channel. Each channel would look like this...
posted_image
Or you can wire the subs together in Series/Parallel for a 4ohm total load and Bridge the amp (if your 2-channel amp will accept a bridge, most do) like this...
posted_image
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Date Posted: March 08, 2004 at 1:07 PM
Alright I am kind of confused but is this what I need to do?
posted_image
Date Posted: March 08, 2004 at 2:42 PM
Both the above diagrams above are correct.
Date Posted: March 08, 2004 at 6:17 PM
You got it
Squirrel
