two amps an a battery
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28063
Printed Date: April 17, 2026 at 11:11 AM
Topic: two amps an a battery
Posted By: southside
Subject: two amps an a battery
Date Posted: March 09, 2004 at 2:20 PM
i wanted to kno how i hook two amps together an hook that with a capacitor an a battery suggestion would be great.
southsider
Date Posted: March 09, 2004 at 4:55 PM
an this for a 86 cutlass supreme
southsider
Posted By: xTimx
Date Posted: March 10, 2004 at 6:40 PM
first of all things get two distrobution blocks 1 for your ground 1 for your power, run your power from your battery to your cap. then run your ground to your cap as well, next run both the ground and power to each distro block, but you have to make sure the distro block for your ground is as close as possible to your amps, then run your ground and power from your distro block to your amps. plain and simple.
xTimx
Date Posted: March 10, 2004 at 6:45 PM
thank u
southsider
