1993 Toyota Previa
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28161
Printed Date: April 13, 2026 at 8:37 AM
Topic: 1993 Toyota Previa
Posted By: omr663
Subject: 1993 Toyota Previa
Date Posted: March 10, 2004 at 11:56 PM
Is there an amplifier on the previa?  Where is it located in the car?  Thanks.
Posted By: itmdtr
Date Posted: March 16, 2004 at 8:51 PM
From my info it looks like its behind the dash, below the AC/HTR controls.
itmdtr
Posted By: jimmeezgolfvr6
Date Posted: March 16, 2004 at 10:19 PM
out of all the previas that i've done audio work for (about half dozen or so at least), i don't recall any of them having a factory amplifier.
Posted By: Metra Tech
Date Posted: March 17, 2004 at 9:40 AM
They do have amps on some models and they are located under the dash in the center. From the amp you can use a standard Toyota harness, Metra part# 70-1761. You can also use the amp with part# 70-8112. And sometimes you get lucky and there is amp jumpers in the dash cavity. Look for blue harness' wrapped together stuffed in the cavity somewhere. If so, unplug them and use a standard Toyota harness.
