Blowing Fuses
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28165
Printed Date: April 13, 2026 at 5:01 AM
Topic: Blowing Fuses
Posted By: cdn_moose
Subject: Blowing Fuses
Date Posted: March 11, 2004 at 12:57 AM
I just bought a used Keenwood 728S and when I replaced my old amp it work, for a few minutes.  Later in the day I found it not working.  Checked fuses and found them blown so I replaced them and have done so 8 times with no luck getting the amp to work.  I wired another amp in my car to double check my wires and all seems good.  Any suggestions?
Posted By: jimmeezgolfvr6
Date Posted: March 11, 2004 at 6:55 AM
your amp is fried....i had the same problem with i think the exact same amp a while back. you can consider getting it repaired at a electronics repair shop, but it's almost not worth it. a new amp is really not all that expensive. even after repair, it's highly likely that the same problem will occur again....that's what happened to me.
good luck
Posted By: lagatbezan
Date Posted: March 11, 2004 at 4:34 PM
what kind of subs do you have hooked up to it?  is it possible you are running the amp lower than 4 ohms?
Date Posted: March 12, 2004 at 12:57 AM
I'm only pushing 1 Kenwood 12" KFC-W3005 @ 4 ohms.
Posted By: superstreet786
Date Posted: March 16, 2004 at 7:38 PM
The power supply may be bad
---- 1996 Chevy S10 ----
1 Lightning Audio S2.600.2 Amp
2 Lightning Audio 12" Subs
1 Lightning Audio 1 Farad Cap
Date Posted: March 16, 2004 at 8:03 PM
Thanks for replying,  I had the Amp checked and the power supply is bad.  Does anybody have any idea roughly how much the repair cost should be to fix it so I know if I'm getting ripped off?
