amp wont shut off
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28320
Printed Date: April 08, 2026 at 10:04 PM
Topic: amp wont shut off
Posted By: iamme9182
Subject: amp wont shut off
Date Posted: March 13, 2004 at 8:22 PM
hi, i went out to my car and found my battery dead. after jumping it and trying to figure out why i found that my amp will not shutoff when the car is turned off. i was just wondering how the remote wire works. i can unplug that and it turns off but as soon as i plug it back in the amp turns right back on. its not a problem(well it really is) if i drive my car everyday but as i found out if i dont for a day the battery is dead. any advice?
Posted By: auex
Date Posted: March 13, 2004 at 9:25 PM
You need to hook the remote wire up to either the remote turn on wire on an aftermarket deck or to an accessory wire on the back of a stock radio.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: superstreet786
Date Posted: March 14, 2004 at 4:34 PM
The remote wire is just a 12 volt power source but it only sends out that power when your deck turns on
------------- ---- 1996 Chevy S10 ----
1 Lightning Audio S2.600.2 Amp
2 Lightning Audio 12" Subs
1 Lightning Audio 1 Farad Cap
Posted By: raydawg357
Date Posted: March 16, 2004 at 3:45 PM
When properly connected, the remote wire is actually your on/off switch for your amp. As mentioned above, it needs to be connected to your remote turn on wire or to the accy wire of an oem deck.
------------- Do it right the first time
Posted By: southside
Date Posted: March 16, 2004 at 6:45 PM
check to see if your power wire on your amp is toching anything else. i had a problem with that an my power wire was touching i think the remote wire. so see if that helps u out at all. do the simple stuff first, the look at getting a switch put on it after.
------------- southsider
Date Posted: March 16, 2004 at 7:02 PM
the remote wire is a 12 volt power source that only turns on when your deck does
Date Posted: March 16, 2004 at 10:56 PM
yes but if the amp is still on then the power wire is touching something to keep it on
Date Posted: March 17, 2004 at 6:46 AM
If your amp is still on then you have your remote wire connected to a constant source instead of a switched source. There is even the possibility of a faulty amp.
Posted By: Teamrf
Date Posted: March 17, 2004 at 10:43 AM
If you've used the blue/white wire on your HU then you should try using a toggle switch. If this doesn't work you may have a bad amp issue.
------------- ~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: markcars
Date Posted: March 17, 2004 at 4:32 PM
Will the amp turn on without the remote wire being connected? Which HU and which Amp are you using? That way I can check the specs to be sure.
Date Posted: March 18, 2004 at 7:12 AM
No, the remote wire is the on and off switch for your amp
Posted By: markcars
Date Posted: March 18, 2004 at 11:22 AM
So it really is the ON switch. Power from that remote wire switches a relay inside the amp on, which in turn turns on the amp. If that power is cut off, the relay won't be energized and the amp won't be on. Then, if your amp does not go off, the power to that remote-wire is never getting cut out. Check that.
