remote wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28352
Printed Date: April 08, 2026 at 7:29 AM
Topic: remote wire
Posted By: iamme9182
Subject: remote wire
Date Posted: March 14, 2004 at 1:58 PM
if the remote wire is not working on my HU can i connect it to anything else, like the 12v line from the ignition?
Posted By: Metra Tech
Date Posted: March 14, 2004 at 2:30 PM
Are you referring to your amps turn on wire? If so, yes you can connect it to 12v accessory.
Posted By: USMC860222
Date Posted: March 14, 2004 at 2:49 PM
ya make sure you hook up a switch though to your bat + because if not it will drain your batt
Date Posted: March 14, 2004 at 3:37 PM
does the ignition wire give a constant power?
Posted By: superstreet786
Date Posted: March 14, 2004 at 4:28 PM
if I were you id do the same thing I did... some people dont like it but it was alright for me.  Get a constant power wire like one going to your deck and hook up your remote wire off that with a switch by your front seat... you just have to remember to turn it off when u get outta ur car
---- 1996 Chevy S10 ----
1 Lightning Audio S2.600.2 Amp
2 Lightning Audio 12" Subs
1 Lightning Audio 1 Farad Cap
