dB estimate?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28450
Printed Date: April 05, 2026 at 11:17 PM
Topic: dB estimate?
Posted By: AudioBAHNvlcm
Subject: dB estimate?
Date Posted: March 15, 2004 at 11:31 PM
Okay, currently i have 2 memphis mojo 15"s with a "cut-cab" box. with about 12 cuft ported. i currently have them running off of an Audiobahn A2200HCT. i am getting a memphis mojo amp (2000D) this friday. Does anyone have any idea on how loud it will be ( as far as dB's go) i would just like a rough estimate without having to get metered.
Posted By: pain
Date Posted: March 15, 2004 at 11:39 PM
I would say that if the box was designed correctly you should be at 153db if not a little bit higher like 155 or 156db.. Just my guess  I hit 154.1 with a 15" solo-baric L7 with about 2500w on it..
Cya l8r,
Pain
Posted By: RufNUSD
Date Posted: March 15, 2004 at 11:42 PM
Probably 3-400db. There is a good chance your ears will explode while the volume is on 1. No one in the world could predict this without knowing exactly all the specifics of your vehicle, even then..... its impossible unless they did theirs the exact same.
Someone pass me that bottle.
Posted By: Ketel22
Date Posted: March 16, 2004 at 12:05 AM
even with the exact same setups there is still too many variables to decide what the spl or sq will be in any set up in any car.
Quad L Handyman services
